  <title>CAD Forum discussion (EN) : password protect issue</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : password protect issue]]></description>
  <pubDate>Fri, 04 Sep 2026 07:24:25 +0000</pubDate>
  <lastBuildDate>Tue, 15 Sep 2015 13:05:37 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=11355</WebWizForums:feedURL>
   <title><![CDATA[password protect issue : Start with the Overkill command....]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11355&amp;PID=30414&amp;title=password-protect-issue#30414</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 11355<br /><strong>Posted:</strong> 15.Sep.2015 at 13:05<br /><br />Start with the Overkill command.&nbsp; You should be in the Drafting and Annotation workspace.&nbsp; Look on the Home tab &gt; Modify panel for an icon that looks like a broom.<br><br>OVERKILL<br>Removes duplicate or overlapping lines, arcs, and polylines. Also, combines partially overlapping or contiguous ones.<br><br>Next run the command line version of the Purge command.&nbsp; This is preceded by a dash so it look like this: -purge.<br><br>Purge Regapps first.&nbsp; Repeat the command but this time select the All option.<br><br>PURGE<br>Removes unused items, such as block definitions and layers, from the drawing.<br><br>Finally, run the Audit command and when AutoCAD asks if you want it to fix any errors it finds answer Yes.<br><br>AUDIT<br>Evaluates the integrity of a drawing and corrects some errors.&nbsp; It does this by examining the drawing's database.<br><br>Do a Zoom &gt; Extents then Save your drawing.<br><br>I'd repeat the entire process a second time just to be sure you did not miss anything.&nbsp; If you are still having problems with a drawing then we must take further measures.<br><br>Got all that?&nbsp; Good.&nbsp; Now go do it.<br>]]>
   <pubDate>Tue, 15 Sep 2015 13:05:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11355&amp;PID=30414&amp;title=password-protect-issue#30414</guid>
   <title><![CDATA[password protect issue :  The CAD teacher is requiring...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11355&amp;PID=30395&amp;title=password-protect-issue#30395</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=584244">jadeaton27</a><br /><strong>Subject:</strong> 11355<br /><strong>Posted:</strong> 12.Sep.2015 at 23:27<br /><br />The CAD teacher is requiring a password for all files. <div>I have not done a purge, audit or overkill.</div><div>Could you please tell me how to go about this?</div><div>thank you</div>]]>
   <pubDate>Sat, 12 Sep 2015 23:27:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11355&amp;PID=30395&amp;title=password-protect-issue#30395</guid>
   <title><![CDATA[password protect issue : Why are you even using the PASSWORD...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11355&amp;PID=30394&amp;title=password-protect-issue#30394</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 11355<br /><strong>Posted:</strong> 12.Sep.2015 at 22:48<br /><br />Why are you even using the PASSWORD feature in the first place?&nbsp; Do you share a computer with someone else?&nbsp; <br><br>Sounds like a REPAIR of the installation may be in order.&nbsp; Note that a REPAIR is NOT the same as an UNINSTALL/REINSTALL.&nbsp; There is no need to go to that extreme.<br><br>Just curious though.&nbsp; Have you done any kind of a cleanup on this drawing file?&nbsp; Run -Purge command?&nbsp; Run Audit command?&nbsp; Run Overkill command?<br><span style="font-size:10px"><br /><br />Edited by John Connor - 12.Sep.2015 at 22:49</span>]]>
   <pubDate>Sat, 12 Sep 2015 22:48:11 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11355&amp;PID=30394&amp;title=password-protect-issue#30394</guid>
   <title><![CDATA[password protect issue :  I am unable to password protect...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11355&amp;PID=30393&amp;title=password-protect-issue#30393</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=584244">jadeaton27</a><br /><strong>Subject:</strong> 11355<br /><strong>Posted:</strong> 12.Sep.2015 at 18:21<br /><br />I am unable to password protect my files. When I hit the security options tab, AutoCAD freezes and becomes unresponsive.<div>I go to the file menu and then hit 'save as'. In this window I go to the top right corner and hit 'tools' followed by 'security options'. Now everything freezes instead of bringing up another window where I can generate a password.</div><div>Does anyone know what the problem is? AutoCAD is working fine otherwise.</div><div>I have windows and AutoCAD 2015.</div><div>Cheers for any help!</div>]]>
   <pubDate>Sat, 12 Sep 2015 18:21:23 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11355&amp;PID=30393&amp;title=password-protect-issue#30393</guid>
