  <title>CAD Forum discussion (EN) : Export to .jpg</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Export to .jpg]]></description>
  <pubDate>Sat, 05 Sep 2026 15:56:43 +0000</pubDate>
  <lastBuildDate>Thu, 01 Oct 2015 12:31:30 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=11384</WebWizForums:feedURL>
   <title><![CDATA[Export to .jpg : I would not use the method you...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11384&amp;PID=30499&amp;title=export-to-jpg#30499</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 11384<br /><strong>Posted:</strong> 01.Oct.2015 at 12:31<br /><br />I would not use the method you described above.&nbsp; Instead I would use a screen capture program like SnagIt or the Windows Snipping tool.<br><br>You could also take a multi-step approach and first use the free Primo PDF program to create a PDF then open the file using the free Gimp program, bring the PDF in and export to the JPG format.&nbsp; You can change the resolution when you export and in the end get better results. <br><span style="font-size:10px"><br /><br />Edited by John Connor - 01.Oct.2015 at 12:33</span>]]>
   <pubDate>Thu, 01 Oct 2015 12:31:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11384&amp;PID=30499&amp;title=export-to-jpg#30499</guid>
   <title><![CDATA[Export to .jpg : I&amp;#039;m trying to work out if...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11384&amp;PID=30497&amp;title=export-to-jpg#30497</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=244354">LeeP</a><br /><strong>Subject:</strong> 11384<br /><strong>Posted:</strong> 01.Oct.2015 at 11:37<br /><br />I'm trying to work out if it's possible to export a drawing to jpg format at a certain size 5000 x 5000 pixels?<div><br></div><div>Exporting the drawing is no problem, but I cannot work out how to define the jpg size. The exported files appear very small and detail is indistinct.</div><div><br></div><div>Can anyone point me in the right direction please?</div><div><br></div><div>Thanks</div>]]>
   <pubDate>Thu, 01 Oct 2015 11:37:16 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11384&amp;PID=30497&amp;title=export-to-jpg#30497</guid>
