  <title>CAD Forum discussion (EN) : STEEL FRAME - QUICK ASSEMBLY Rev.1</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : STEEL FRAME - QUICK ASSEMBLY Rev.1]]></description>
  <pubDate>Sat, 18 Jul 2026 01:57:45 +0000</pubDate>
  <lastBuildDate>Mon, 19 Oct 2015 11:35:03 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=11422</WebWizForums:feedURL>
   <title><![CDATA[STEEL FRAME - QUICK ASSEMBLY Rev.1 : I still don&amp;#039;t know why you...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11422&amp;PID=30680&amp;title=steel-frame-quick-assembly-rev1#30680</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 11422<br /><strong>Posted:</strong> 19.Oct.2015 at 11:35<br /><br />I still don't know why you think the diameter of the tank is of no concern.<br><br>I'd put lugs on the tank and attach it to the frame shipped as one complete unit.&nbsp; The crane lifts the unit into place and you're done.&nbsp; Temporary, tack welded pipe, can be used to keep the frame square along with wood blocking to keep things from shifting as it is transported to the site.<br><br>It would have been better had you continue to post in your first thread regarding this subject rather than start a second, virtually duplicate, thread.&nbsp; Less confusion for those wishing to follow the conversation and it keep all the pertinent information in one place rather than spread between two threads.&nbsp; <br><span style="font-size:10px"><br /><br />Edited by John Connor - 19.Oct.2015 at 13:16</span>]]>
   <pubDate>Mon, 19 Oct 2015 11:35:03 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11422&amp;PID=30680&amp;title=steel-frame-quick-assembly-rev1#30680</guid>
   <title><![CDATA[STEEL FRAME - QUICK ASSEMBLY Rev.1 : Hi there guys.I posted this topic...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11422&amp;PID=30676&amp;title=steel-frame-quick-assembly-rev1#30676</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=568677">Vini-SA Engineering</a><br /><strong>Subject:</strong> 11422<br /><strong>Posted:</strong> 18.Oct.2015 at 22:41<br /><br />Hi there guys.&nbsp;<div><br></div><div>I posted this topic yesterday hoping someone might have an practical, as built, quick assembly drawing or idea of a gantry in order to build a tank bigger than 5m in diameter. hence the parameters of between 5 and 10m. I need the frame to be plus minus 16m high. What i didn't add in my previous post is the exact diameter (inconsequential really) but which is of relevance is the maximum weight it needs to lift.</div><div><br></div><div>12,000 to 14,000 kg is the maximum weight i will need to lift with this frame.</div><div><br></div><div>The remote locations where these tanks are to be erected makes using a crane too costly mr JC. A crane must be present at the time of site establishment but even that time needs to be as short as possible</div><div><br></div><div>I've included &nbsp;a hand sketch of more or less what we need.</div><div><br></div><div>G<img src="uploads/568677/sketch.jpg" height="493" width="820" border="0" /></div><span style="font-size:10px"><br /><br />Edited by Vini-SA Engineering - 18.Oct.2015 at 22:47</span>]]>
   <pubDate>Sun, 18 Oct 2015 22:41:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11422&amp;PID=30676&amp;title=steel-frame-quick-assembly-rev1#30676</guid>
