  <title>CAD Forum discussion (EN) : Quad Copter Body</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : CAD - general : Quad Copter Body]]></description>
  <pubDate>Fri, 02 Oct 2026 14:14:42 +0000</pubDate>
  <lastBuildDate>Tue, 20 Oct 2015 12:42:38 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=11430</WebWizForums:feedURL>
   <title><![CDATA[Quad Copter Body : Example of surfaces created via...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11430&amp;PID=30706&amp;title=quad-copter-body#30706</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 11430<br /><strong>Posted:</strong> 20.Oct.2015 at 12:42<br /><br />Example of surfaces created via the LOFT command using some of your geometry.<br><br><img src="uploads/165260/3D_Surfaces.JPG" height="680" width="725" border="0" /><br>]]>
   <pubDate>Tue, 20 Oct 2015 12:42:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11430&amp;PID=30706&amp;title=quad-copter-body#30706</guid>
   <title><![CDATA[Quad Copter Body : Have you tried the LOFT command?...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11430&amp;PID=30705&amp;title=quad-copter-body#30705</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 11430<br /><strong>Posted:</strong> 20.Oct.2015 at 12:30<br /><br />Have you tried the LOFT command?<br>]]>
   <pubDate>Tue, 20 Oct 2015 12:30:48 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11430&amp;PID=30705&amp;title=quad-copter-body#30705</guid>
   <title><![CDATA[Quad Copter Body : I designed a quad copter case...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11430&amp;PID=30702&amp;title=quad-copter-body#30702</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=592377">Juaquine</a><br /><strong>Subject:</strong> 11430<br /><strong>Posted:</strong> 20.Oct.2015 at 01:21<br /><br />I designed a quad copter case and am hoping to 3d print it.&nbsp; To that end I have a wireframe of the shape I want and I am trying to stretch a surface between multiple plines which are not closed and each are on different planes.&nbsp; None of the commands seem to do what I need.&nbsp; Anyone have any ideas?<br><br>BTW, here is a link to the case file itself:<br>https://drive.google.com/file/d/0B1icptHaGVuvQUhKN1Rrbjk5N2M/view?usp=sharing<br>]]>
   <pubDate>Tue, 20 Oct 2015 01:21:34 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11430&amp;PID=30702&amp;title=quad-copter-body#30702</guid>
