  <title>CAD Forum discussion (EN) : Interested in revit</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : Revit : Interested in revit]]></description>
  <pubDate>Sat, 15 Aug 2026 13:01:08 +0000</pubDate>
  <lastBuildDate>Thu, 09 Oct 2008 18:43:05 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=1150</WebWizForums:feedURL>
   <title><![CDATA[Interested in revit : With Revit Structure, if you create...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1150&amp;PID=3198&amp;title=interested-in-revit#3198</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=21644">PaulJ</a><br /><strong>Subject:</strong> 1150<br /><strong>Posted:</strong> 09.Oct.2008 at 18:43<br /><br />With Revit Structure, if you create the timber parts as families, then yes, it will count all the parts and pieces for you, provided you can work the proper schedule parameters.  It should also be able to check your load calculations with whatever type of structural analysis software you're currently using.  Revit Structure is compatible with several analysis programs on the market.  Your best bet is to talk to a reseller than has a Revit Structure Application Engineer to get the best answers.]]>
   <pubDate>Thu, 09 Oct 2008 18:43:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1150&amp;PID=3198&amp;title=interested-in-revit#3198</guid>
   <title><![CDATA[Interested in revit :     Hody!I&amp;#039;m interested...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1150&amp;PID=3104&amp;title=interested-in-revit#3104</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=20590">Insener07</a><br /><strong>Subject:</strong> 1150<br /><strong>Posted:</strong> 30.Sep.2008 at 11:09<br /><br />   Hody!<br>I'm interested in using Revit structure. But i would like to know something first. <br>My work is to design timber structure wall, floor, roof panels. <br>We I thinking of using 3D modeling program but we can't find suitable program. <br>What should the program do generally.<br>It should be able to draw entire house in 3D.<br>Itshould be able to generate construction figures automatically(in thesame platform) and count all the materials so i do not have to draweverything in AutoCAD and count all the materials by hand. <br>Is it possible using Revit structure?<br>Thanks,<br>M]]>
   <pubDate>Tue, 30 Sep 2008 11:09:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1150&amp;PID=3104&amp;title=interested-in-revit#3104</guid>
