  <title>CAD Forum discussion (EN) : Help with XREF&#039;s</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Help with XREF&#039;s]]></description>
  <pubDate>Sun, 06 Sep 2026 10:20:54 +0000</pubDate>
  <lastBuildDate>Sat, 04 Oct 2008 02:45:30 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=1151</WebWizForums:feedURL>
   <title><![CDATA[Help with XREF&#039;s : Only one copy XREF, it&amp;#039;s...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1151&amp;PID=3128&amp;title=help-with-xrefs#3128</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=18476">nguyenhuyhoang</a><br /><strong>Subject:</strong> 1151<br /><strong>Posted:</strong> 04.Oct.2008 at 02:45<br /><br /><P>Only one copy XREF, it's OK</P>]]>
   <pubDate>Sat, 04 Oct 2008 02:45:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1151&amp;PID=3128&amp;title=help-with-xrefs#3128</guid>
   <title><![CDATA[Help with XREF&#039;s : Jou can use a relative path of...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1151&amp;PID=3125&amp;title=help-with-xrefs#3125</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=20994">Kackac</a><br /><strong>Subject:</strong> 1151<br /><strong>Posted:</strong> 03.Oct.2008 at 17:55<br /><br />Jou can use a relative path of the xref - retain only the path from the current drawing directory in the xref dialog, e.g. "drawing1.dwg" as a path instead of "c:/directory1/direcotry2/drawing1.dwg" or you can use dotted form too, e.g. "../elsedirectory/drawing1.dwg".<br>I know, it's a lot of work on 30 files, but it works without problems then.<br>]]>
   <pubDate>Fri, 03 Oct 2008 17:55:48 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1151&amp;PID=3125&amp;title=help-with-xrefs#3125</guid>
   <title><![CDATA[Help with XREF&#039;s : THX, But i have for example 30...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1151&amp;PID=3124&amp;title=help-with-xrefs#3124</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=20624">Tool</a><br /><strong>Subject:</strong> 1151<br /><strong>Posted:</strong> 03.Oct.2008 at 11:43<br /><br /><P>THX,</P><P>But i have for example 30 files, all of them referenced to the same xref file. But if&nbsp;i save each file with etransmite it will generate a folder with an external reference for each one of them. what&nbsp;i need&nbsp;is to have all the 30 files with a single xref file so i can save them all in a cd. How can i do that?????</P>]]>
   <pubDate>Fri, 03 Oct 2008 11:43:33 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1151&amp;PID=3124&amp;title=help-with-xrefs#3124</guid>
   <title><![CDATA[Help with XREF&#039;s : You use ETRANSMIT for save your...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1151&amp;PID=3121&amp;title=help-with-xrefs#3121</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=18476">nguyenhuyhoang</a><br /><strong>Subject:</strong> 1151<br /><strong>Posted:</strong> 02.Oct.2008 at 18:02<br /><br />You use ETRANSMIT for save your drawing - it's OK]]>
   <pubDate>Thu, 02 Oct 2008 18:02:28 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1151&amp;PID=3121&amp;title=help-with-xrefs#3121</guid>
   <title><![CDATA[Help with XREF&#039;s : Hello, I have a doubt regarding...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1151&amp;PID=3105&amp;title=help-with-xrefs#3105</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=20624">Tool</a><br /><strong>Subject:</strong> 1151<br /><strong>Posted:</strong> 30.Sep.2008 at 15:42<br /><br /><SPAN =post>Hello, <BR>I have a doubt regarding xref's and their path. I have several drawings which are using an external reference on a specific location/path. I would like to know if i can save all these drawings to a cd (files which are using the xref file and the xref file itself) and if they will mantain their relation. Basically i need to put them all in a cd but i m afraid that the reference to the xref file might get lost while burning them... How can i assure that the xref relation doesn't get lost??? <BR><BR>Thanx <BR></SPAN>]]>
   <pubDate>Tue, 30 Sep 2008 15:42:14 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1151&amp;PID=3105&amp;title=help-with-xrefs#3105</guid>
