  <title>CAD Forum discussion (EN) : Cleaning up drawings (join/overkill)</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Cleaning up drawings (join/overkill)]]></description>
  <pubDate>Fri, 04 Sep 2026 19:21:21 +0000</pubDate>
  <lastBuildDate>Wed, 15 Jun 2016 11:26:13 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=11607</WebWizForums:feedURL>
   <title><![CDATA[Cleaning up drawings (join/overkill) :   carlos rebeka wrote:The perfect...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11607&amp;PID=32011&amp;title=cleaning-up-drawings-join-overkill#32011</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 11607<br /><strong>Posted:</strong> 15.Jun.2016 at 11:26<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Originally posted by carlos rebeka" alt="Originally posted by carlos rebeka" style="vertical-align: text-bottom;" /> <strong>carlos rebeka wrote:</strong><br /><br />The perfect solution is&nbsp;<span style="color: rgb102, 102, 102; font-family: Helvetica, arial, sans-serif; font-size: 14.5px; line-height: 20px; : rgb249, 249, 249;">Duplicate Files Deleter</span></td></tr></table><br><br>Actually that is NOT the perfect solution and has nothing at all to do with the subject of this thread.&nbsp; Go pedal your crap somewhere else.&nbsp; <br>]]>
   <pubDate>Wed, 15 Jun 2016 11:26:13 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11607&amp;PID=32011&amp;title=cleaning-up-drawings-join-overkill#32011</guid>
   <title><![CDATA[Cleaning up drawings (join/overkill) : The perfect solution isDuplicate...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11607&amp;PID=32010&amp;title=cleaning-up-drawings-join-overkill#32010</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=656971">carlos rebeka</a><br /><strong>Subject:</strong> 11607<br /><strong>Posted:</strong> 15.Jun.2016 at 09:02<br /><br />The perfect solution is&nbsp;<span style="color: rgb102, 102, 102; font-family: Helvetica, arial, sans-serif; font-size: 14.5px; line-height: 20px; : rgb249, 249, 249;">Duplicate Files Deleter</span>]]>
   <pubDate>Wed, 15 Jun 2016 09:02:47 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11607&amp;PID=32010&amp;title=cleaning-up-drawings-join-overkill#32010</guid>
   <title><![CDATA[Cleaning up drawings (join/overkill) : Hi Fiberty does your company have...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11607&amp;PID=31241&amp;title=cleaning-up-drawings-join-overkill#31241</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=617918">EamonFleming</a><br /><strong>Subject:</strong> 11607<br /><strong>Posted:</strong> 27.Jan.2016 at 20:07<br /><br />Hi Fiberty does your company have a subscription for AutoCAD? if so you can request a Home Use license code to use at home.<br><br>I did this as I sometimes work from home instead of staying late for OT<br><br>Eamon <br>]]>
   <pubDate>Wed, 27 Jan 2016 20:07:53 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11607&amp;PID=31241&amp;title=cleaning-up-drawings-join-overkill#31241</guid>
   <title><![CDATA[Cleaning up drawings (join/overkill) : There are always AutoCAD clones....]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11607&amp;PID=31235&amp;title=cleaning-up-drawings-join-overkill#31235</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 11607<br /><strong>Posted:</strong> 27.Jan.2016 at 17:11<br /><br />There are always AutoCAD clones.&nbsp; For example....CorelCAD.&nbsp; It lists for $699 U.S.&nbsp; It has both 2D and 3D capability and supports native .DWG file format.<br><br>]]>
   <pubDate>Wed, 27 Jan 2016 17:11:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11607&amp;PID=31235&amp;title=cleaning-up-drawings-join-overkill#31235</guid>
   <title><![CDATA[Cleaning up drawings (join/overkill) : I know that no free program will...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11607&amp;PID=31234&amp;title=cleaning-up-drawings-join-overkill#31234</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=617599">Flibertygibbet</a><br /><strong>Subject:</strong> 11607<br /><strong>Posted:</strong> 27.Jan.2016 at 17:04<br /><br />I know that no free program will be as fully featured as AutoCAD.<br><br>I use AutoCAD and Inventor at work - when you make good use of them in terms of the time you spend using them and the range features you use, they are more than worth paying for.<br><br>I was just hoping that, as it is just the one function I need (running OVERKILL on all elements of a 2D dwg or dxf), I might get lucky and there might be an alternative out there.<br><br>As it is, I have downloaded the AutoCAD free trial, so I can complete the current project, but as you say it's not a long term solution.<br>]]>
   <pubDate>Wed, 27 Jan 2016 17:04:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11607&amp;PID=31234&amp;title=cleaning-up-drawings-join-overkill#31234</guid>
   <title><![CDATA[Cleaning up drawings (join/overkill) :  No free 3D CAD program will...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11607&amp;PID=31225&amp;title=cleaning-up-drawings-join-overkill#31225</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 11607<br /><strong>Posted:</strong> 26.Jan.2016 at 23:31<br /><br />No free 3D CAD program will have the same functionality as AutoCAD or Inventor.<br><br>Download a free 30-day trial of either (or both) and design quickly.]]>
   <pubDate>Tue, 26 Jan 2016 23:31:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11607&amp;PID=31225&amp;title=cleaning-up-drawings-join-overkill#31225</guid>
   <title><![CDATA[Cleaning up drawings (join/overkill) : Hi all,I&amp;#039;m hoping for a little...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11607&amp;PID=31224&amp;title=cleaning-up-drawings-join-overkill#31224</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=617599">Flibertygibbet</a><br /><strong>Subject:</strong> 11607<br /><strong>Posted:</strong> 26.Jan.2016 at 21:55<br /><br />Hi all,<br><br>I'm hoping for a little advice - I've searched around, but with no luck, and its a slightly specific question:<br><br>Outside work, I've started using Fusion360 to create models for cutting on a CNC router - I can get dxf outputs for the profiles to be cut, but they're relatively messy, with many duplicate lines, long lines made up of multiple shorter lines etc.<br><br>I've used JOIN and OVERKILL in AutoCAD before, and that kind of functionality would be ideal to clean up these drawings - unfortunately I dont have access to AutoCAD outside work.<br><br>So, does anyone know of any more affordable (that is to say, free) CAD software that has simlar capabilities, as I can't justify the expense of AutoCAD just to fulfil this one function.<br><br>Thanks,<br><br>Andy<br>]]>
   <pubDate>Tue, 26 Jan 2016 21:55:23 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11607&amp;PID=31224&amp;title=cleaning-up-drawings-join-overkill#31224</guid>
