  <title>CAD Forum discussion (EN) : Opening dwg in Autocad 2016LT</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Opening dwg in Autocad 2016LT]]></description>
  <pubDate>Tue, 08 Sep 2026 05:02:58 +0000</pubDate>
  <lastBuildDate>Fri, 11 Mar 2016 17:38:09 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=11691</WebWizForums:feedURL>
   <title><![CDATA[Opening dwg in Autocad 2016LT : Glad to hear you got your problem...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11691&amp;PID=31474&amp;title=opening-dwg-in-autocad-2016lt#31474</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 11691<br /><strong>Posted:</strong> 11.Mar.2016 at 17:38<br /><br />Glad to hear you got your problem resolved.<br>]]>
   <pubDate>Fri, 11 Mar 2016 17:38:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11691&amp;PID=31474&amp;title=opening-dwg-in-autocad-2016lt#31474</guid>
   <title><![CDATA[Opening dwg in Autocad 2016LT : Thanks John Connor and Edwin....]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11691&amp;PID=31473&amp;title=opening-dwg-in-autocad-2016lt#31473</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=286389">BvdS3340</a><br /><strong>Subject:</strong> 11691<br /><strong>Posted:</strong> 11.Mar.2016 at 17:10<br /><br />Thanks John Connor and Edwin. Yes, it was a video card / graphics issue and the solution is to be found in the Autodesk Knowledge base: https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Unwanted-linework-appears-when-opening-drawings-in-AutoCAD-2015.html<br />For me the problem is solved. To John: on the  page mentioned above you can find an example of the problem described.]]>
   <pubDate>Fri, 11 Mar 2016 17:10:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11691&amp;PID=31473&amp;title=opening-dwg-in-autocad-2016lt#31473</guid>
   <title><![CDATA[Opening dwg in Autocad 2016LT : My guess it you have graphic adapter...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11691&amp;PID=31470&amp;title=opening-dwg-in-autocad-2016lt#31470</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=150189">edwinprakoso</a><br /><strong>Subject:</strong> 11691<br /><strong>Posted:</strong> 11.Mar.2016 at 09:29<br /><br />My guess it you have graphic adapter issue, check this solution on Autodesk Knowledge Network:&nbsp;<a href="http://https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Unwanted-linework-appears-when-opening-drawings-in-AutoCAD-2015.html" target="_blank" rel="nofollow">Unwanted linework appears when opening drawings in AutoCAD 2015/2016</a>]]>
   <pubDate>Fri, 11 Mar 2016 09:29:14 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11691&amp;PID=31470&amp;title=opening-dwg-in-autocad-2016lt#31470</guid>
   <title><![CDATA[Opening dwg in Autocad 2016LT : Attach a copy of the drawing to...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11691&amp;PID=31468&amp;title=opening-dwg-in-autocad-2016lt#31468</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 11691<br /><strong>Posted:</strong> 11.Mar.2016 at 00:21<br /><br />Attach a copy of the drawing to your next post and I'll open it up on my computer using AutoCAD 2016 to see if the same thing happens.<br><br>Personally, I don't think it has anything to do with the version of AutoCAD that the drawing was saved in because I open drawings from many versions of AutoCAD dating as far back as 1985 and have no problems that sound like what you described.<br><br>Any problems creating a new drawing with LT 2016?<br>]]>
   <pubDate>Fri, 11 Mar 2016 00:21:32 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11691&amp;PID=31468&amp;title=opening-dwg-in-autocad-2016lt#31468</guid>
   <title><![CDATA[Opening dwg in Autocad 2016LT : I just installed a trial version...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11691&amp;PID=31464&amp;title=opening-dwg-in-autocad-2016lt#31464</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=286389">BvdS3340</a><br /><strong>Subject:</strong> 11691<br /><strong>Posted:</strong> 10.Mar.2016 at 20:25<br /><br />I just installed a trial version of Autocad 2016 LT. When I open a drawing saved as Autocad R14 or Autocad 2011, I get a weird pattern of lines on my screen, looking like a spider web. I cannot select these lines to find out what they are. It looks as if it has to do with dimensions and leaders, but not all of them. One or 2 lines coming from the 0,0 coĂ¶rd.The pattern shows in model space as well as in the lay-out.<br />Any one who has a clue?<br />]]>
   <pubDate>Thu, 10 Mar 2016 20:25:15 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11691&amp;PID=31464&amp;title=opening-dwg-in-autocad-2016lt#31464</guid>
