  <title>CAD Forum discussion (EN) : License info in created drawings</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : License info in created drawings]]></description>
  <pubDate>Fri, 17 Jul 2026 14:39:33 +0000</pubDate>
  <lastBuildDate>Fri, 18 Mar 2016 10:04:35 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=11698</WebWizForums:feedURL>
   <title><![CDATA[License info in created drawings : If a drawing is saved in a DXF...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11698&amp;PID=31504&amp;title=license-info-in-created-drawings#31504</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 11698<br /><strong>Posted:</strong> 18.Mar.2016 at 10:04<br /><br />If a drawing is saved in a DXF format then opened with an ASCII text editor the header information will tell the user what version of AutoCAD the drawing was saved to.&nbsp; So, for example, if you opened the file and looked for the entry $ACADVER and saw AC1024 this would mean the drawing was saved to the AutoCAD 2010 file format.&nbsp; <br><br>To my knowledge there is no "license" information contained within the file.&nbsp; For that information one would have to look in the Window's Registry.&nbsp; I don't know if the information in the DXF file would also tell someone whether or not an educational version was used.&nbsp; <br><br>Now at one time there was a lisp routine available that would warn users when they were about to open a drawing that was created with an educational version of the program but I don't know if it is still available or if it would pick up on drawings saved in versions of AutoCAD that no longer included the educational banner.&nbsp; Do you understand all that?<br><br><i>Update: I found that lisp routine but in the description it clearly states the last supported platform the product supported was AutoCAD 2002.</i><br><br><span style="font-size:10px"><br /><br />Edited by John Connor - 18.Mar.2016 at 13:26</span>]]>
   <pubDate>Fri, 18 Mar 2016 10:04:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11698&amp;PID=31504&amp;title=license-info-in-created-drawings#31504</guid>
   <title><![CDATA[License info in created drawings : Hi!Do you know if Autodesk product...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11698&amp;PID=31501&amp;title=license-info-in-created-drawings#31501</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=575526">csubuka</a><br /><strong>Subject:</strong> 11698<br /><strong>Posted:</strong> 17.Mar.2016 at 23:07<br /><br />Hi!<div><br></div><div>Do you know if Autodesk product do store licensing info in th files you created with them? I do not want to get my company into trouble. *I definitely mean that if at home I am using student version to finish up something, but these days with the regular one you can remove the watermark... but would that make it untraceable that you used a student version to create it originally...etc?</div>]]>
   <pubDate>Thu, 17 Mar 2016 23:07:32 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11698&amp;PID=31501&amp;title=license-info-in-created-drawings#31501</guid>
