  <title>CAD Forum discussion (EN) : Errror Message :invalid in CanonicalMediaName</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Errror Message :invalid in CanonicalMediaName]]></description>
  <pubDate>Sun, 13 Sep 2026 03:07:48 +0000</pubDate>
  <lastBuildDate>Wed, 06 Apr 2016 17:24:27 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=11744</WebWizForums:feedURL>
   <title><![CDATA[Errror Message :invalid in CanonicalMediaName : Hi i am getting invalid input...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11744&amp;PID=31650&amp;title=errror-message-invalid-in-canonicalmedianame#31650</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=637184">PrasadUddanti</a><br /><strong>Subject:</strong> 11744<br /><strong>Posted:</strong> 06.Apr.2016 at 17:24<br /><br />Hi i am getting invalid input error message while assigning CanonicalMediaName=ANSI_E_(44.00_x_34.00_Inches)<div>please help on that</div><div><br></div><div><br></div><div>&nbsp;</div><div>Please see the below VB.Net Code</div><div>&nbsp;</div><div>Dim rasterObj As Autodesk.AutoCAD.Interop.Common.IAcadEntity</div><div>Dim Layout As Autodesk.AutoCAD.Interop.Common.AcadLayout</div><div>Dim l_SheetCount As Integer</div><div>Dim NewFile, codespot As String</div><div>Dim i As Integer</div><div>Dim resume2 As Boolean = True</div><div>Try</div><div>codespot = "SAP 1"</div><div>NewFile = "monochrome.ctb"</div><div>l_SheetCount = CInt(clsVariable.DrawingSheet)</div><div>codespot = "SAP 2"</div><div>Layout = Acad.ActiveDocument.ModelSpace.Layout</div><div>codespot = "SAP 3"</div><div>rasterObj = Layout.Block.Item(l_SheetCount - 1)</div><div>If Not (Layout.CanonicalMediaName = "ANSI_E_(44.00_x_34.00_Inches)") Then</div><div>Layout.CanonicalMediaName = "ANSI_E_(44.00_x_34.00_Inches)"</div><div>End If</div><div>Layout.PlotRotation = Autodesk.AutoCAD.Interop.Common.AcPlotRotation.ac0degrees</div><div>codespot = "SAP 5"</div><div>If Not (Layout.StyleSheet = NewFile) Then</div><div>Layout.StyleSheet = NewFile</div><div>If Not (Layout.StyleSheet = NewFile) Then ''if the style sheet can't be set, use none</div><div>Layout.StyleSheet = ""</div><div>End If</div><div>End If</div><div><br></div><div>codespot = "SAP 6"</div><div>Layout.PaperUnits = Autodesk.AutoCAD.Interop.Common.AcPlotPaperUnits.acInches</div><div>codespot = "SAP 7"</div><div>Layout.StandardScale = Autodesk.AutoCAD.Interop.Common.AcPlotScale.acScaleToFit</div><div>codespot = "SAP 8"</div><div>i = 0</div><div>'Layout = Acad.ActiveDocument.Layers.Add("Junk") 'commented prasad</div><div>Acad.ActiveDocument.Layers.Add("Junk")</div><div>'Set the layer named "Junk" the active layer for the current document</div><div>Acad.ActiveDocument.ActiveLayer = Acad.ActiveDocument.Layers.Item("Junk")</div><div><br></div><div>Acad.ActiveDocument.ActiveLayout.PlotType = Autodesk.AutoCAD.Interop.Common.AcPlotType.acExtents</div><div>Acad.ActiveDocument.ModelSpace.Layout.ConfigName = "HybridConverter.pc3" --Getting Error in this line</div><div>''Acad.ActiveDocument.Regen acActiveViewport</div><div>Acad.ActiveDocument.ModelSpace.Layout.RefreshPlotDeviceInfo()</div><div><br></div><div>Acad.ActiveDocument.ActiveLayer = Acad.ActiveDocument.Layers.Item("0")</div><div>Layout = Acad.ActiveDocument.Layers.Item("Junk")</div><div>Layout.Delete()</div><div><br></div><div>codespot = "SAP 9"</div><div>Application.DoEvents()</div><div>Acad.Update()</div><div>Application.DoEvents()</div>]]>
   <pubDate>Wed, 06 Apr 2016 17:24:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11744&amp;PID=31650&amp;title=errror-message-invalid-in-canonicalmedianame#31650</guid>
