  <title>CAD Forum discussion (EN) : Text display issue</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Text display issue]]></description>
  <pubDate>Sun, 06 Sep 2026 05:10:23 +0000</pubDate>
  <lastBuildDate>Tue, 20 Dec 2016 11:37:36 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=12150</WebWizForums:feedURL>
   <title><![CDATA[Text display issue : What font is being used?Is the...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12150&amp;PID=33064&amp;title=text-display-issue#33064</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 12150<br /><strong>Posted:</strong> 20.Dec.2016 at 11:37<br /><br />What font is being used?<br><br>Is the text annotative?<br><br>If you start a new drawing and insert a keynote in it does the same problem occur?<br><br>Can you attach a copy of the drawing to your next post so we can take a look at it ourselves?&nbsp; Images are nice but one cannot troubleshoot a problem properly using an image.<br>]]>
   <pubDate>Tue, 20 Dec 2016 11:37:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12150&amp;PID=33064&amp;title=text-display-issue#33064</guid>
   <title><![CDATA[Text display issue :  I would take a damaged font...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12150&amp;PID=33063&amp;title=text-display-issue#33063</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 12150<br /><strong>Posted:</strong> 20.Dec.2016 at 08:29<br /><br />I would take a damaged font file or a graphics card issue as suspects.]]>
   <pubDate>Tue, 20 Dec 2016 08:29:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12150&amp;PID=33063&amp;title=text-display-issue#33063</guid>
   <title><![CDATA[Text display issue : Hi all!Hopefully someone with...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12150&amp;PID=33062&amp;title=text-display-issue#33062</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=694738">mardix</a><br /><strong>Subject:</strong> 12150<br /><strong>Posted:</strong> 20.Dec.2016 at 03:43<br /><br /><div>Hi all!</div><div><br></div><div>Hopefully someone with more CAD knowledge then me can help me with my problem</div><div><br></div>I have on and off trouble with text within my keynotes not displaying correctly. &nbsp;(see screenshot)<div>I am running AutoCAD 2015 and cant seem to resolve the problem. The keynotes are set up as blocks with attributes.</div><div><br></div><div><img src="uploads/694738/Capture.JPG" height="349" width="817" border="0" align="left" /><br></div><div><br></div><div><br></div><div><br></div><div><br></div><div><br></div><div><br></div><div><br></div><div><br></div><div><br></div><div><br></div><div><br></div><div><br></div><div><br></div><div><br></div><div>If I change the text in an affected key note it displays properly for awhile, only to distort again when the file is closed and re-opened. &nbsp;The affected keynotes appear to be random and change each time the file is opened. &nbsp;Sometimes they are slightly distorted like the attached pics, but other times they have large lines going every which way across the screen. &nbsp;It seems to only be affecting a couple of computers in the office, others can open the same file with no distortion.</div><div><br></div><div>Is anyone familiar with this issue? &nbsp;Help!</div><div><br></div><div>Thanks</div><div>Ken</div>]]>
   <pubDate>Tue, 20 Dec 2016 03:43:24 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12150&amp;PID=33062&amp;title=text-display-issue#33062</guid>
