  <title>CAD Forum discussion (EN) : Dynamic-dynamic block</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Dynamic-dynamic block]]></description>
  <pubDate>Sat, 05 Sep 2026 08:43:17 +0000</pubDate>
  <lastBuildDate>Thu, 12 Jan 2017 11:33:51 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=12169</WebWizForums:feedURL>
   <title><![CDATA[Dynamic-dynamic block :  You can create combined visibility...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12169&amp;PID=33121&amp;title=dynamicdynamic-block#33121</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 12169<br /><strong>Posted:</strong> 12.Jan.2017 at 11:33<br /><br />You can create combined visibility states (4x4=16 of them) or you can employ lookup tables - see e.g.<div><a href="http://forums.autodesk.com/t5/dynamic-blocks/ootb-multiple-visibility-states-solution/td-p/4961288" target="_blank" rel="nofollow">http://forums.autodesk.com/t5/dynamic-blocks/ootb-multiple-visibility-states-solution/td-p/4961288</a></div>]]>
   <pubDate>Thu, 12 Jan 2017 11:33:51 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12169&amp;PID=33121&amp;title=dynamicdynamic-block#33121</guid>
   <title><![CDATA[Dynamic-dynamic block : Hi all,I have 4 dynamic blocks...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12169&amp;PID=33120&amp;title=dynamicdynamic-block#33120</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=341466">gegenytibor</a><br /><strong>Subject:</strong> 12169<br /><strong>Posted:</strong> 11.Jan.2017 at 18:17<br /><br />Hi all,<br /><br />I have 4 dynamic blocks and each has 4 different visibility states.<br />I would like to create a dynamic block which contains the previous 4 dynamic blocks and where I can set the different blocks different visibility states (like the drop down menu).<br /><br />Is it possible somehow?<br />Or should I make all of the possibilities visibility states?<br /><br />Please help if you can!<br />Thank you!<br />]]>
   <pubDate>Wed, 11 Jan 2017 18:17:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12169&amp;PID=33120&amp;title=dynamicdynamic-block#33120</guid>
