  <title>CAD Forum discussion (EN) : transparency</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : CAD - general : transparency]]></description>
  <pubDate>Tue, 07 Apr 2026 00:58:56 +0000</pubDate>
  <lastBuildDate>Mon, 30 Jan 2017 18:32:33 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=12193</WebWizForums:feedURL>
   <title><![CDATA[transparency : Maybe you should have mentioned...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12193&amp;PID=34240&amp;title=transparency#34240</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 12193<br /><strong>Posted:</strong> 30.Jan.2017 at 18:32<br /><br />Maybe you should have mentioned what program you were working in when you posted your question.&nbsp; That would have helped.&nbsp; You list AutoCAD 2013 under your screen name.<br><span style="font-size:10px"><br /><br />Edited by John Connor - 30.Jan.2017 at 18:34</span>]]>
   <pubDate>Mon, 30 Jan 2017 18:32:33 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12193&amp;PID=34240&amp;title=transparency#34240</guid>
   <title><![CDATA[transparency : i&amp;#039;am using doublecad xt Edited...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12193&amp;PID=34239&amp;title=transparency#34239</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=698511">f.gerard</a><br /><strong>Subject:</strong> 12193<br /><strong>Posted:</strong> 30.Jan.2017 at 17:36<br /><br />i'am using doublecad xt<br><br><br><img src="" border="0" /><span style="font-size:10px"><br /><br />Edited by f.gerard - 30.Jan.2017 at 17:38</span>]]>
   <pubDate>Mon, 30 Jan 2017 17:36:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12193&amp;PID=34239&amp;title=transparency#34239</guid>
   <title><![CDATA[transparency : Didn&amp;#039;t understand one word...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12193&amp;PID=34238&amp;title=transparency#34238</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 12193<br /><strong>Posted:</strong> 30.Jan.2017 at 17:23<br /><br />Didn't understand one word of that.&nbsp; What program were you doing this in?<br>]]>
   <pubDate>Mon, 30 Jan 2017 17:23:34 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12193&amp;PID=34238&amp;title=transparency#34238</guid>
   <title><![CDATA[transparency : For exclude a surface include...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12193&amp;PID=34237&amp;title=transparency#34237</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=698511">f.gerard</a><br /><strong>Subject:</strong> 12193<br /><strong>Posted:</strong> 30.Jan.2017 at 16:56<br /><br />For exclude a surface include in an other by 2d bolean you can select the object to exclude and from which other<br>after if you use the brush the surface exclude is not fill !<br><br>regards<br><img src="https://www.cadforum.cz/forum_en/smileys/smiley1.gif" border="0" alt="Smile" title="Smile" /><br>]]>
   <pubDate>Mon, 30 Jan 2017 16:56:57 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12193&amp;PID=34237&amp;title=transparency#34237</guid>
   <title><![CDATA[transparency :  And what exactly did you do?...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12193&amp;PID=34236&amp;title=transparency#34236</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 12193<br /><strong>Posted:</strong> 28.Jan.2017 at 12:07<br /><br />And what exactly did you do?]]>
   <pubDate>Sat, 28 Jan 2017 12:07:32 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12193&amp;PID=34236&amp;title=transparency#34236</guid>
   <title><![CDATA[transparency : i have found the solution using...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12193&amp;PID=34235&amp;title=transparency#34235</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=698511">f.gerard</a><br /><strong>Subject:</strong> 12193<br /><strong>Posted:</strong> 28.Jan.2017 at 08:32<br /><br />i have found the solution using 2 d boleean operation ! <br><br>]]>
   <pubDate>Sat, 28 Jan 2017 08:32:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12193&amp;PID=34235&amp;title=transparency#34235</guid>
   <title><![CDATA[transparency : Transparency is layer specific...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12193&amp;PID=34214&amp;title=transparency#34214</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 12193<br /><strong>Posted:</strong> 25.Jan.2017 at 18:20<br /><br />Transparency is layer specific isn't it?&nbsp; The range is 0-90.<br>]]>
   <pubDate>Wed, 25 Jan 2017 18:20:11 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12193&amp;PID=34214&amp;title=transparency#34214</guid>
   <title><![CDATA[transparency : helloi would like to insert on...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12193&amp;PID=34213&amp;title=transparency#34213</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=698511">f.gerard</a><br /><strong>Subject:</strong> 12193<br /><strong>Posted:</strong> 25.Jan.2017 at 18:15<br /><br />hello<br>i would like to insert on the face wall a window overlapping the structure of the wall brush rock)<br>i have not find a command for the transparency<br>many tanks <br>]]>
   <pubDate>Wed, 25 Jan 2017 18:15:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12193&amp;PID=34213&amp;title=transparency#34213</guid>
