  <title>CAD Forum discussion (EN) : Autocad-Autocad</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Autocad-Autocad]]></description>
  <pubDate>Sat, 05 Sep 2026 03:43:52 +0000</pubDate>
  <lastBuildDate>Fri, 24 Feb 2017 09:10:16 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=12230</WebWizForums:feedURL>
   <title><![CDATA[Autocad-Autocad :  No need to worry - the drawings...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12230&amp;PID=34367&amp;title=autocadautocad#34367</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 12230<br /><strong>Posted:</strong> 24.Feb.2017 at 09:10<br /><br />No need to worry - the drawings are upwards compatible and the command set is the same. You get a couple of additional new commands and support for newer DWG file formats.]]>
   <pubDate>Fri, 24 Feb 2017 09:10:16 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12230&amp;PID=34367&amp;title=autocadautocad#34367</guid>
   <title><![CDATA[Autocad-Autocad :  Generally speaking you should...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12230&amp;PID=34366&amp;title=autocadautocad#34366</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 12230<br /><strong>Posted:</strong> 23.Feb.2017 at 23:52<br /><br />Generally speaking you should be OK.&nbsp; There is the "Ribbon" to contend with as the Dashboard has gone the way of the dodo bird.&nbsp; There are toolbars and tool palettes now but you can still access the drop-down menus if you want.&nbsp; You may feel lost for a couple of days but that should be the extent of it.&nbsp; If you remember command aliases like "L" for Line and "M" for Move then you should be fine.]]>
   <pubDate>Thu, 23 Feb 2017 23:52:25 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12230&amp;PID=34366&amp;title=autocadautocad#34366</guid>
   <title><![CDATA[Autocad-Autocad :  Ok , is a newer AutoCAD (2017...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12230&amp;PID=34365&amp;title=autocadautocad#34365</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=159408">BLOB</a><br /><strong>Subject:</strong> 12230<br /><strong>Posted:</strong> 23.Feb.2017 at 23:46<br /><br />Ok , is a newer AutoCAD (2017 ) the same as using a 2006&nbsp;&nbsp; Drafting commands? tool sets? <div></div>I guess my question would be : with my ability using 2006 ..would I be able to just start using 2017? <div>&nbsp;</div><div>Bob</div>]]>
   <pubDate>Thu, 23 Feb 2017 23:46:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12230&amp;PID=34365&amp;title=autocadautocad#34365</guid>
   <title><![CDATA[Autocad-Autocad : You can only legally upgrade to...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12230&amp;PID=34355&amp;title=autocadautocad#34355</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 12230<br /><strong>Posted:</strong> 22.Feb.2017 at 19:24<br /><br />You can only legally upgrade to the latest release which would be AutoCAD 2017.&nbsp; And technically speaking it would not be an upgrade as there is no path for upgrading from 2006 all the way to 2017.&nbsp; You basically buy a new license to install/run 2017.&nbsp; There is also a yearly subscription fee which can run a few hundred dollars or more depending where you are located in the world.&nbsp; Any AutoCAD product that came after AutoCAD 2006, from 2007 all the way up to 2017, could conceivably open the drawings that were created with AutoCAD 2006.&nbsp; <br><span style="font-size:10px"><br /><br />Edited by John Connor - 22.Feb.2017 at 19:25</span>]]>
   <pubDate>Wed, 22 Feb 2017 19:24:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12230&amp;PID=34355&amp;title=autocadautocad#34355</guid>
   <title><![CDATA[Autocad-Autocad :  We are using AutoCAD 2006 for...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12230&amp;PID=34352&amp;title=autocadautocad#34352</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=159408">BLOB</a><br /><strong>Subject:</strong> 12230<br /><strong>Posted:</strong> 22.Feb.2017 at 18:50<br /><br />We are using AutoCAD 2006 for some drawings and to export them to a plasma cutting table control (DXF)<div>we are looking to upgrade to a newer AutoCAD . What newer version will work with the drawings I have already?&nbsp;</div><div>Any help with this would be great </div><div>&nbsp;</div><div>&nbsp;</div><div>&nbsp;</div><div>Thanks,Reds</div>]]>
   <pubDate>Wed, 22 Feb 2017 18:50:17 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12230&amp;PID=34352&amp;title=autocadautocad#34352</guid>
