  <title>CAD Forum discussion (EN) : dim ext off</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : dim ext off]]></description>
  <pubDate>Sat, 05 Sep 2026 07:22:37 +0000</pubDate>
  <lastBuildDate>Fri, 21 Apr 2017 21:22:49 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=12297</WebWizForums:feedURL>
   <title><![CDATA[dim ext off : Thanks Kent! ]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12297&amp;PID=34602&amp;title=dim-ext-off#34602</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=423875">pweeks</a><br /><strong>Subject:</strong> 12297<br /><strong>Posted:</strong> 21.Apr.2017 at 21:22<br /><br />Thanks Kent!<br>]]>
   <pubDate>Fri, 21 Apr 2017 21:22:49 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12297&amp;PID=34602&amp;title=dim-ext-off#34602</guid>
   <title><![CDATA[dim ext off :   pweeks wrote:Hey guys,....I...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12297&amp;PID=34601&amp;title=dim-ext-off#34601</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=353260">Kent Cooper</a><br /><strong>Subject:</strong> 12297<br /><strong>Posted:</strong> 20.Apr.2017 at 23:07<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Originally posted by pweeks" alt="Originally posted by pweeks" style="vertical-align: text-bottom;" /> <strong>pweeks wrote:</strong><br /><br />Hey guys,<br>....&nbsp;I need to turn off both of the EXT lines in the dim.&nbsp;.... can I create a macro or a lisp command that will allow me to turn these off? <br>....<br></td></tr></table><div>&nbsp;</div><div><strong><font size="2">^c^cDIMOVERRIDE DIMSE1 ON DIMSE2 ON ;</font></strong></div><div>&nbsp;</div><div>That will leave you at the prompt to select Dimensions, as many as you want to change all at once, by any selection method(s) and options you like.&nbsp;&nbsp;You&nbsp;could also&nbsp;make one that's self-repeating, letting you pick just one, and you would see the change immediately as you pick each one.&nbsp; But then you'd have to select them all one at a time, and couldn't use Window or Crossing selection, etc.</div><div>&nbsp;</div><div>But I agree that if you know ahead of time you want a Dimension to not show extension lines, it's probably better to&nbsp;set a different Style that has them suppressed, before you draw it, rather than draw it first and then turn the extension lines off after the fact.</div>]]>
   <pubDate>Thu, 20 Apr 2017 23:07:46 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12297&amp;PID=34601&amp;title=dim-ext-off#34601</guid>
   <title><![CDATA[dim ext off : I&amp;#039;ve never uttered a witty...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12297&amp;PID=34600&amp;title=dim-ext-off#34600</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 12297<br /><strong>Posted:</strong> 20.Apr.2017 at 20:12<br /><br />I've never uttered a witty comment in my life.<br>]]>
   <pubDate>Thu, 20 Apr 2017 20:12:49 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12297&amp;PID=34600&amp;title=dim-ext-off#34600</guid>
   <title><![CDATA[dim ext off : I&amp;#039;m combining your idea with...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12297&amp;PID=34599&amp;title=dim-ext-off#34599</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=423875">pweeks</a><br /><strong>Subject:</strong> 12297<br /><strong>Posted:</strong> 20.Apr.2017 at 20:05<br /><br />I'm combining your idea with mine. Creating a dim style and going to either make a macro to set selected dims to the created dim style you referenced. Or just customize my ribbon to include dim styles in the home tab. I don't know why but switching tabs is annoying to me. Your idea will be implemented John. Thanks as always. I strive to achieve your knowledge in CAD and sarcastic/witty comments. <img src="https://www.cadforum.cz/forum_en/smileys/smiley36.gif" border="0" alt="LOL" title="LOL" /><br>]]>
   <pubDate>Thu, 20 Apr 2017 20:05:08 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12297&amp;PID=34599&amp;title=dim-ext-off#34599</guid>
   <title><![CDATA[dim ext off : Suit yourself. In the time it...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12297&amp;PID=34597&amp;title=dim-ext-off#34597</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 12297<br /><strong>Posted:</strong> 20.Apr.2017 at 19:43<br /><br />Suit yourself.&nbsp; In the time it takes to click on the macro you could just as easily select a different dimstyle.<br>]]>
   <pubDate>Thu, 20 Apr 2017 19:43:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12297&amp;PID=34597&amp;title=dim-ext-off#34597</guid>
   <title><![CDATA[dim ext off : I&amp;#039;ve been becoming a fan...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12297&amp;PID=34595&amp;title=dim-ext-off#34595</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=423875">pweeks</a><br /><strong>Subject:</strong> 12297<br /><strong>Posted:</strong> 20.Apr.2017 at 19:20<br /><br />I've been becoming a fan of creating custom ribbon macro's. I can probably create a macro that will set a selection to a dim style with your suppression. Just my preference right now I guess. Thanks John<br>]]>
   <pubDate>Thu, 20 Apr 2017 19:20:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12297&amp;PID=34595&amp;title=dim-ext-off#34595</guid>
   <title><![CDATA[dim ext off : Why bother? Make a copy of your...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12297&amp;PID=34594&amp;title=dim-ext-off#34594</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 12297<br /><strong>Posted:</strong> 20.Apr.2017 at 17:56<br /><br />Why bother?&nbsp; Make a copy of your dimension style and look at the Lines tab.&nbsp; Place checkmarks where it says....<br><br>Supress:&nbsp; __Ext Line 1&nbsp;&nbsp; __Ext Line 2<br><br>Switch between the original and the copy for your different dimensional needs.&nbsp; No programming needed.<br><span style="font-size:10px"><br /><br />Edited by John Connor - 20.Apr.2017 at 17:57</span>]]>
   <pubDate>Thu, 20 Apr 2017 17:56:11 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12297&amp;PID=34594&amp;title=dim-ext-off#34594</guid>
   <title><![CDATA[dim ext off : Hey guys,Sometimes when creating...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12297&amp;PID=34593&amp;title=dim-ext-off#34593</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=423875">pweeks</a><br /><strong>Subject:</strong> 12297<br /><strong>Posted:</strong> 20.Apr.2017 at 17:36<br /><br />Hey guys,<br><br>Sometimes when creating my associative dimensions I will come across cases where I need to turn off both of the EXT lines in the dim. I usually achieve this by going through the Properties bar and turning Ext Line 1 and 2 from ON to OFF. <br><br>Not sure if it is possible but can I create a macro or a lisp command that will allow me to turn these off? <br><br>I'm more knowledgeable in Macros so if there is a possibility through that I would really appreciate it.<br><br>Thanks<br>]]>
   <pubDate>Thu, 20 Apr 2017 17:36:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12297&amp;PID=34593&amp;title=dim-ext-off#34593</guid>
