  <title>CAD Forum discussion (EN) : Offset Command</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Offset Command]]></description>
  <pubDate>Sun, 06 Sep 2026 07:43:08 +0000</pubDate>
  <lastBuildDate>Wed, 03 May 2017 20:24:59 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=12322</WebWizForums:feedURL>
   <title><![CDATA[Offset Command :   John Connor wrote:... Maybe...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12322&amp;PID=34691&amp;title=offset-command#34691</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=353260">Kent Cooper</a><br /><strong>Subject:</strong> 12322<br /><strong>Posted:</strong> 03.May.2017 at 20:24<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Originally posted by John Connor" alt="Originally posted by John Connor" style="vertical-align: text-bottom;" /> <strong>John Connor wrote:</strong><br /><br />... Maybe it has a "Z" other than "0".<br></td></tr></table><div><br></div><div>Can't be that -- Offsetting a Line with a Delta Z works for me. &nbsp;Is it on a <i>locked Layer?</i> &nbsp;Is it really a Line <i>entity</i>, and not &#091;for example&#093; a <i>Block</i> that contains the Line, or a Circle or Arc that you're looking at edgewise, or ...?</div><span style="font-size:10px"><br /><br />Edited by Kent Cooper - 03.May.2017 at 20:26</span>]]>
   <pubDate>Wed, 03 May 2017 20:24:59 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12322&amp;PID=34691&amp;title=offset-command#34691</guid>
   <title><![CDATA[Offset Command : Just a line? Hmmm. Did you check...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12322&amp;PID=34689&amp;title=offset-command#34689</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 12322<br /><strong>Posted:</strong> 03.May.2017 at 18:19<br /><br />Just a line?&nbsp; Hmmm.&nbsp; Did you check its properties?&nbsp; Maybe it has a "Z" other than "0".<br>]]>
   <pubDate>Wed, 03 May 2017 18:19:52 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12322&amp;PID=34689&amp;title=offset-command#34689</guid>
   <title><![CDATA[Offset Command : I am just offsetting a line. ]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12322&amp;PID=34688&amp;title=offset-command#34688</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=724657">Chefhef</a><br /><strong>Subject:</strong> 12322<br /><strong>Posted:</strong> 03.May.2017 at 18:16<br /><br />I am just offsetting a line.<div><br></div>]]>
   <pubDate>Wed, 03 May 2017 18:16:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12322&amp;PID=34688&amp;title=offset-command#34688</guid>
   <title><![CDATA[Offset Command : What is the item you are attempting...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12322&amp;PID=34687&amp;title=offset-command#34687</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 12322<br /><strong>Posted:</strong> 03.May.2017 at 18:02<br /><br />What is the item you are attempting to offset?]]>
   <pubDate>Wed, 03 May 2017 18:02:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12322&amp;PID=34687&amp;title=offset-command#34687</guid>
   <title><![CDATA[Offset Command : Autocad 2013 LT question:When...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12322&amp;PID=34686&amp;title=offset-command#34686</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=724657">Chefhef</a><br /><strong>Subject:</strong> 12322<br /><strong>Posted:</strong> 03.May.2017 at 17:52<br /><br />Autocad 2013 LT question:<div>When trying to do an offset command, I am able to pick the item, and when I try to select which side to offset to, a circle with a line thru it appears. Help please!!</div><div><br></div>]]>
   <pubDate>Wed, 03 May 2017 17:52:42 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12322&amp;PID=34686&amp;title=offset-command#34686</guid>
