  <title>CAD Forum discussion (EN) : Secure my work</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Secure my work]]></description>
  <pubDate>Thu, 09 Jul 2026 11:18:23 +0000</pubDate>
  <lastBuildDate>Thu, 11 May 2017 21:20:26 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=12327</WebWizForums:feedURL>
   <title><![CDATA[Secure my work : Thank you all for your ideas.I&amp;#039;ll...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12327&amp;PID=34740&amp;title=secure-my-work#34740</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=520444">avastardis</a><br /><strong>Subject:</strong> 12327<br /><strong>Posted:</strong> 11.May.2017 at 21:20<br /><br />Thank you all for your ideas.<div>I'll check them and I'll write my impressions</div><div><div><br></div></div>]]>
   <pubDate>Thu, 11 May 2017 21:20:26 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12327&amp;PID=34740&amp;title=secure-my-work#34740</guid>
   <title><![CDATA[Secure my work :   avastardis wrote:Hello All.......]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12327&amp;PID=34718&amp;title=secure-my-work#34718</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=353260">Kent Cooper</a><br /><strong>Subject:</strong> 12327<br /><strong>Posted:</strong> 08.May.2017 at 15:02<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Originally posted by avastardis" alt="Originally posted by avastardis" style="vertical-align: text-bottom;" /> <strong>avastardis wrote:</strong><br /><br />Hello &nbsp;All<div>.... It is possible to create the template or the file to work on a given computer and up to an expiration date.</div><div>....</div></td></tr></table><div>&nbsp;</div><div>On the expiration date question, there have been several threads about that kind of thing on the AutoCAD Customization Forum.&nbsp; <a href="http://https://forums.autodesk.com/t5/forums/searchpage/tab/message?advanced=false&amp;allow_punctuation=false&amp;filter=location&amp;location=forum-board%3A130&amp;q=expire" target="_blank" rel="nofollow">Here</a> is a Search there for just the word "expire," but try some other similar terms.&nbsp; If none of them has a foolproof solution, at least the discussions will show you why it's difficult (or impossible, perhaps).</div><div>&nbsp;</div><div>EDIT:&nbsp; That doesn't seem to be working as a hyperlink.&nbsp; Try it this way:<br><a href="https://forums.autodesk.com/t5/forums/searchpage/tab/message?advanced=false&amp;allow_punctuation=false&amp;filter=location&amp;location=forum-board%3A130&amp;q=expire" target="_blank" rel="nofollow">https://forums.autodesk.com/t5/forums/searchpage/tab/message?advanced=false&amp;allow_punctuation=false&amp;filter=location&amp;location=forum-board%3A130&amp;q=expire</a></div><span style="font-size:10px"><br /><br />Edited by Kent Cooper - 08.May.2017 at 15:05</span>]]>
   <pubDate>Mon, 08 May 2017 15:02:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12327&amp;PID=34718&amp;title=secure-my-work#34718</guid>
   <title><![CDATA[Secure my work :  I doubt you can &amp;#034;expire&amp;#034;...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12327&amp;PID=34716&amp;title=secure-my-work#34716</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 12327<br /><strong>Posted:</strong> 08.May.2017 at 13:29<br /><br />I doubt you can "expire" a file contents. But you can sign it and prove that some is using it illegally. See <a href="http://www.cadstudio.cz/dwgsign" target="_blank" rel="nofollow">DWGsign</a>.]]>
   <pubDate>Mon, 08 May 2017 13:29:17 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12327&amp;PID=34716&amp;title=secure-my-work#34716</guid>
   <title><![CDATA[Secure my work : Wouldn&amp;#039;t you have to know...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12327&amp;PID=34712&amp;title=secure-my-work#34712</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 12327<br /><strong>Posted:</strong> 05.May.2017 at 19:36<br /><br />Wouldn't you have to know the exact specifications of the "given computer" in order to write an exclusive code?&nbsp;]]>
   <pubDate>Fri, 05 May 2017 19:36:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12327&amp;PID=34712&amp;title=secure-my-work#34712</guid>
   <title><![CDATA[Secure my work : If one can break it, he will not...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12327&amp;PID=34711&amp;title=secure-my-work#34711</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=520444">avastardis</a><br /><strong>Subject:</strong> 12327<br /><strong>Posted:</strong> 05.May.2017 at 19:20<br /><br />If one can break it, he will not have to take the template, blocks etc we have made, surely he will have better. Anyway, I'm looking for something simple if one is determined to bypass it then let him do it.]]>
   <pubDate>Fri, 05 May 2017 19:20:57 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12327&amp;PID=34711&amp;title=secure-my-work#34711</guid>
   <title><![CDATA[Secure my work : I would doubt it. Anyway, if you...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12327&amp;PID=34710&amp;title=secure-my-work#34710</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 12327<br /><strong>Posted:</strong> 04.May.2017 at 19:58<br /><br />I would doubt it.&nbsp; Anyway, if you found a way to do it then someone else could find a way to undo it.<br>]]>
   <pubDate>Thu, 04 May 2017 19:58:46 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12327&amp;PID=34710&amp;title=secure-my-work#34710</guid>
   <title><![CDATA[Secure my work : Hello AllI have created a template...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12327&amp;PID=34709&amp;title=secure-my-work#34709</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=520444">avastardis</a><br /><strong>Subject:</strong> 12327<br /><strong>Posted:</strong> 04.May.2017 at 19:54<br /><br />Hello &nbsp;All<div>I have created a template that I give to outsiders who make the final designs, which may sometimes be modified before they take their final form. I want to restrict the possibility that somebody will be able to use ready-made work after the end of our cooperation. My question is the following. It is possible to create the template or the file to work on a given computer and up to an expiration date.</div><div>Thank you</div><div>A.V.</div>]]>
   <pubDate>Thu, 04 May 2017 19:54:15 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12327&amp;PID=34709&amp;title=secure-my-work#34709</guid>
