  <title>CAD Forum discussion (EN) : Vertical Section command</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Vertical Section command]]></description>
  <pubDate>Sat, 05 Sep 2026 22:23:14 +0000</pubDate>
  <lastBuildDate>Wed, 10 May 2017 15:07:36 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=12333</WebWizForums:feedURL>
   <title><![CDATA[Vertical Section command : yes 2016 AutoCAD Architecture ]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12333&amp;PID=34734&amp;title=vertical-section-command#34734</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=457559">cabinetmaker</a><br /><strong>Subject:</strong> 12333<br /><strong>Posted:</strong> 10.May.2017 at 15:07<br /><br />yes 2016 AutoCAD Architecture]]>
   <pubDate>Wed, 10 May 2017 15:07:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12333&amp;PID=34734&amp;title=vertical-section-command#34734</guid>
   <title><![CDATA[Vertical Section command : Are you using AutoCAD Architecture?...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12333&amp;PID=34732&amp;title=vertical-section-command#34732</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 12333<br /><strong>Posted:</strong> 10.May.2017 at 11:28<br /><br />Are you using AutoCAD Architecture?<br>]]>
   <pubDate>Wed, 10 May 2017 11:28:45 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12333&amp;PID=34732&amp;title=vertical-section-command#34732</guid>
   <title><![CDATA[Vertical Section command : This command is not working for...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12333&amp;PID=34728&amp;title=vertical-section-command#34728</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=457559">cabinetmaker</a><br /><strong>Subject:</strong> 12333<br /><strong>Posted:</strong> 09.May.2017 at 22:02<br /><br />This command is not working for me and I even uninstalled and reinstalled ACA2016.<div>It acts like it is working only nothing shows up in the window, had been working fine but I noticed about a week ago it was acting up and now its not working at all.</div><div>Any thoughts??</div><div>Ken&nbsp;</div>]]>
   <pubDate>Tue, 09 May 2017 22:02:06 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12333&amp;PID=34728&amp;title=vertical-section-command#34728</guid>
