  <title>CAD Forum discussion (EN) : Change text lisp routine</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Change text lisp routine]]></description>
  <pubDate>Sat, 05 Sep 2026 00:11:42 +0000</pubDate>
  <lastBuildDate>Tue, 23 May 2017 18:17:28 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=12344</WebWizForums:feedURL>
   <title><![CDATA[Change text lisp routine :  it is just straight M-text. ]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12344&amp;PID=34784&amp;title=change-text-lisp-routine#34784</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=173925">psgbs1</a><br /><strong>Subject:</strong> 12344<br /><strong>Posted:</strong> 23.May.2017 at 18:17<br /><br />it is just straight M-text.]]>
   <pubDate>Tue, 23 May 2017 18:17:28 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12344&amp;PID=34784&amp;title=change-text-lisp-routine#34784</guid>
   <title><![CDATA[Change text lisp routine : psgbs1: Is the text you want to...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12344&amp;PID=34767&amp;title=change-text-lisp-routine#34767</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 12344<br /><strong>Posted:</strong> 22.May.2017 at 13:07<br /><br />psgbs1: Is the text you want to change an attribute?<br>]]>
   <pubDate>Mon, 22 May 2017 13:07:24 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12344&amp;PID=34767&amp;title=change-text-lisp-routine#34767</guid>
   <title><![CDATA[Change text lisp routine : I have similar needs: I have one...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12344&amp;PID=34761&amp;title=change-text-lisp-routine#34761</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=228353">jkaunisto</a><br /><strong>Subject:</strong> 12344<br /><strong>Posted:</strong> 21.May.2017 at 10:53<br /><br />I have similar needs: I have one drawing block (header) filled with up-to-date (attributes) data. Now I need to update hundred blocks (in the same or separate drawings) with almost same data. I should be able to choose which data I have to fill by hand or automated (numbers or patterns) means. What I gain with this is: all data written in the same way of the project and I can concentrate only to information on the header, that must be changed. <br><br>chgtext.lsp makes almost that what you asked at least for text? Try to find that, if you really are using text?!<br>]]>
   <pubDate>Sun, 21 May 2017 10:53:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12344&amp;PID=34761&amp;title=change-text-lisp-routine#34761</guid>
   <title><![CDATA[Change text lisp routine :  good afternoon to one and all.I...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12344&amp;PID=34757&amp;title=change-text-lisp-routine#34757</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=173925">psgbs1</a><br /><strong>Subject:</strong> 12344<br /><strong>Posted:</strong> 16.May.2017 at 17:20<br /><br />good afternoon to one and all.<div></div><div>I have multiple Tabs with the exact&nbsp;same title block and text to be changed in&nbsp;the same location in each tab. </div><div>I am looking for a lisp routine that will seek the same text in each tab and change a number sequentially, i.e. 1 on tab 1 2 on tab 2 etc.</div><div>&nbsp;</div><div>It would save me an inordinate amount of time as vs clicking on each tab and changing the text manually on sometimes up to 250 tabs. </div><div>&nbsp;</div><div>I also need to adjust the viewport on each tab to turn one layer off and the next one on i.e. plot 1 off and plot 2 on, then move the drawing to centre over the plot 2 layer and so on.</div><div>&nbsp;</div><div>I would try and write one myself but don't have a clue where to begin and it sounds quite complicated if&nbsp;it is even possible.</div><div>&nbsp;</div><div>If anyone has something that will help or can advise further on alternatives that will achieve the same thing I would very much appreciate it.</div><div>&nbsp;</div><div>May the cad gods be with you!!! because you will be a god if you can save me all this time!!</div>]]>
   <pubDate>Tue, 16 May 2017 17:20:25 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12344&amp;PID=34757&amp;title=change-text-lisp-routine#34757</guid>
