  <title>CAD Forum discussion (EN) : Batch Plot - Publish</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : CAD - general : Batch Plot - Publish]]></description>
  <pubDate>Sun, 27 Sep 2026 21:50:09 +0000</pubDate>
  <lastBuildDate>Thu, 08 Jun 2017 11:13:52 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=12353</WebWizForums:feedURL>
   <title><![CDATA[Batch Plot - Publish :  check the layout setting first...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12353&amp;PID=34845&amp;title=batch-plot-publish#34845</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=446263">aqeel222</a><br /><strong>Subject:</strong> 12353<br /><strong>Posted:</strong> 08.Jun.2017 at 11:13<br /><br />check the layout setting first in first sheet, make setting as u like. save it, through plot command with Add.. button. then publish. add the drawings &amp; change the page setup as u save in first sheet. see image<div></div><img src="uploads/446263/Capture.PNG" height="332" width="795" border="0" />]]>
   <pubDate>Thu, 08 Jun 2017 11:13:52 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12353&amp;PID=34845&amp;title=batch-plot-publish#34845</guid>
   <title><![CDATA[Batch Plot - Publish : What is your actual question?What...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12353&amp;PID=34786&amp;title=batch-plot-publish#34786</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 12353<br /><strong>Posted:</strong> 24.May.2017 at 11:25<br /><br />What is your actual question?<br><br>What is the exact nature of the error message you are receiving?<br><br>Are you plotting from model space or from a layout?<br><br>Are you plotting to a network printer or a standalone printer?<br><br>Are the plotter drivers up-to-date?<br><br>When asking a question it just makes sense to provide as much information as possible so we can get right to the heart of the problem.<br>]]>
   <pubDate>Wed, 24 May 2017 11:25:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12353&amp;PID=34786&amp;title=batch-plot-publish#34786</guid>
   <title><![CDATA[Batch Plot - Publish : issue with batch plot (publish)...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12353&amp;PID=34785&amp;title=batch-plot-publish#34785</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=587159">mcacic</a><br /><strong>Subject:</strong> 12353<br /><strong>Posted:</strong> 24.May.2017 at 06:36<br /><br />issue with batch plot (publish) from cad to PDF<div>receiving message - encountered problem?</div>]]>
   <pubDate>Wed, 24 May 2017 06:36:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12353&amp;PID=34785&amp;title=batch-plot-publish#34785</guid>
