  <title>CAD Forum discussion (EN) : classicxref</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : CAD - general : classicxref]]></description>
  <pubDate>Mon, 28 Sep 2026 01:32:38 +0000</pubDate>
  <lastBuildDate>Mon, 10 Jul 2017 15:27:36 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=12388</WebWizForums:feedURL>
   <title><![CDATA[classicxref :  I wasn&amp;#039;t aware of the CLASSICXREF...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12388&amp;PID=34915&amp;title=classicxref#34915</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=353260">Kent Cooper</a><br /><strong>Subject:</strong> 12388<br /><strong>Posted:</strong> 10.Jul.2017 at 15:27<br /><br />I wasn't aware of the CLASSICXREF command, but I liked the old one better than the current one, so I tried changing the command alias XR to call up CLASSICXREF.&nbsp; In AutoCAD2016 where I am now, oddly, it didn't "take" when I did it through the ALIASEDIT command, even after it <em>told</em> me XR now refers to CLASSICXREF, even after&nbsp;I closed AutoCAD and started it again, just in case that would make the difference.&nbsp; XR still brought up the XREF command.<div></div><div>But it <em>did</em> work when I opened the ACAD.PGP file in a plain-text editor and changed it there.&nbsp; In any drawing, type in:</div><div>&nbsp;</div><div>(findfile "acad.pgp")</div><div>&nbsp;</div><div>and it will tell you where that file is.&nbsp; Change this:</div><div><br><img src="uploads/353260/XRAlias.PNG" height="81" width="190" border="0" /></div>]]>
   <pubDate>Mon, 10 Jul 2017 15:27:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12388&amp;PID=34915&amp;title=classicxref#34915</guid>
   <title><![CDATA[classicxref : Are you referring to Shortcut...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12388&amp;PID=34914&amp;title=classicxref#34914</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 12388<br /><strong>Posted:</strong> 10.Jul.2017 at 11:15<br /><br />Are you referring to Shortcut Keys or Command Aliases?<br>]]>
   <pubDate>Mon, 10 Jul 2017 11:15:11 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12388&amp;PID=34914&amp;title=classicxref#34914</guid>
   <title><![CDATA[classicxref : classicxref can i use this command...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12388&amp;PID=34913&amp;title=classicxref#34913</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=655620">phool0055</a><br /><strong>Subject:</strong> 12388<br /><strong>Posted:</strong> 10.Jul.2017 at 09:42<br /><br />classicxref can i use this command in shortcut xr i mean i want change classicxref in to xr]]>
   <pubDate>Mon, 10 Jul 2017 09:42:00 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12388&amp;PID=34913&amp;title=classicxref#34913</guid>
