  <title>CAD Forum discussion (EN) : Dimensioning</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : CAD - general : Dimensioning]]></description>
  <pubDate>Mon, 28 Sep 2026 11:17:53 +0000</pubDate>
  <lastBuildDate>Sat, 22 Jul 2017 13:03:07 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=12398</WebWizForums:feedURL>
   <title><![CDATA[Dimensioning : If you had already made up your...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12398&amp;PID=34950&amp;title=dimensioning#34950</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 12398<br /><strong>Posted:</strong> 22.Jul.2017 at 13:03<br /><br />If you had already made up your mind why bother asking the question? &nbsp;Every user should test both methods then select the one that works best for their circumstances. &nbsp;]]>
   <pubDate>Sat, 22 Jul 2017 13:03:07 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12398&amp;PID=34950&amp;title=dimensioning#34950</guid>
   <title><![CDATA[Dimensioning :  Fair comment , But using annotative...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12398&amp;PID=34946&amp;title=dimensioning#34946</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=700216">copperkins2017</a><br /><strong>Subject:</strong> 12398<br /><strong>Posted:</strong> 21.Jul.2017 at 08:59<br /><br />Fair comment , But using annotative dimensioning and notes in model space allows (when required to coy complete details from one drawing to another and then you don't have to re dimension in paper space , as once was said to me 5 and 4 equals 9 , but also 3 x3 = 9 , both are correct ]]>
   <pubDate>Fri, 21 Jul 2017 08:59:13 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12398&amp;PID=34946&amp;title=dimensioning#34946</guid>
   <title><![CDATA[Dimensioning : There are pros and cons to each...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12398&amp;PID=34941&amp;title=dimensioning#34941</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 12398<br /><strong>Posted:</strong> 20.Jul.2017 at 18:34<br /><br />There are pros and cons to each method.&nbsp; Best advice is to take a typical drawing, make a copy then dimension one entirely in model space using annotative scaling and the other dimension entirely in a layout.<br><br>Our company places all text and dimensions in the layout.&nbsp; Model space is reserved strictly for geometry.<br>]]>
   <pubDate>Thu, 20 Jul 2017 18:34:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12398&amp;PID=34941&amp;title=dimensioning#34941</guid>
   <title><![CDATA[Dimensioning :  Dimension in paper or model...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12398&amp;PID=34940&amp;title=dimensioning#34940</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=700216">copperkins2017</a><br /><strong>Subject:</strong> 12398<br /><strong>Posted:</strong> 20.Jul.2017 at 15:32<br /><br />Dimension in paper or model space ? ]]>
   <pubDate>Thu, 20 Jul 2017 15:32:32 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12398&amp;PID=34940&amp;title=dimensioning#34940</guid>
