  <title>CAD Forum discussion (EN) : Sweep</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Sweep]]></description>
  <pubDate>Sat, 05 Sep 2026 03:53:08 +0000</pubDate>
  <lastBuildDate>Fri, 04 Aug 2017 18:50:31 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=12420</WebWizForums:feedURL>
   <title><![CDATA[Sweep : Thank you John for replying so...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12420&amp;PID=35016&amp;title=sweep#35016</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=228353">jkaunisto</a><br /><strong>Subject:</strong> 12420<br /><strong>Posted:</strong> 04.Aug.2017 at 18:50<br /><br />Thank you John for replying so soon!<br><br>I have a dxf including the original profile (2D) and the outside line describing the size of the window frame. I made a simplified pline also, that would surely be enough to visualize the sweeped frame. <br><br>The glas is naturally inside the frame. See 3D<br><br>Hope you will get it somehow. I cannot find you mail right away, but I will try...<br><br>greetings <a href="uploads/228353/Alu1.dwg" target="_blank" rel="nofollow">uploads/228353/Alu1.dwg</a> Jukka<br>]]>
   <pubDate>Fri, 04 Aug 2017 18:50:31 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12420&amp;PID=35016&amp;title=sweep#35016</guid>
   <title><![CDATA[Sweep : Can you attach a copy of your...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12420&amp;PID=35014&amp;title=sweep#35014</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 12420<br /><strong>Posted:</strong> 04.Aug.2017 at 12:28<br /><br />Can you attach a copy of your drawing (not an image) so we can see what you have so far? &nbsp;It should include the profile and a rectangle defining the inside dimensions of the window.]]>
   <pubDate>Fri, 04 Aug 2017 12:28:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12420&amp;PID=35014&amp;title=sweep#35014</guid>
   <title><![CDATA[Sweep : I have a rectangular pline defining...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12420&amp;PID=35013&amp;title=sweep#35013</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=228353">jkaunisto</a><br /><strong>Subject:</strong> 12420<br /><strong>Posted:</strong> 03.Aug.2017 at 21:13<br /><br />I have a rectangular pline defining the size of a aluminium window. Then I have a rather complex pline defining the aluminium profile. How can I have the base of the profile defined so, that my 3D-result after sweeping still is dimensionally accurate? <br>]]>
   <pubDate>Thu, 03 Aug 2017 21:13:46 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12420&amp;PID=35013&amp;title=sweep#35013</guid>
