  <title>CAD Forum discussion (EN) : HELP 3D</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : HELP 3D]]></description>
  <pubDate>Fri, 04 Sep 2026 22:57:09 +0000</pubDate>
  <lastBuildDate>Mon, 14 Aug 2017 11:33:12 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=12433</WebWizForums:feedURL>
   <title><![CDATA[HELP 3D : Fillet is not going to solve the...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12433&amp;PID=35095&amp;title=help-3d#35095</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 12433<br /><strong>Posted:</strong> 14.Aug.2017 at 11:33<br /><br />Fillet is not going to solve the problem in its entirety.<span style="font-size:10px"><br /><br />Edited by John Connor - 14.Aug.2017 at 12:10</span>]]>
   <pubDate>Mon, 14 Aug 2017 11:33:12 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12433&amp;PID=35095&amp;title=help-3d#35095</guid>
   <title><![CDATA[HELP 3D : Hallo again,see the attachement...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12433&amp;PID=35091&amp;title=help-3d#35091</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=87494">scj.schulz</a><br /><strong>Subject:</strong> 12433<br /><strong>Posted:</strong> 12.Aug.2017 at 22:47<br /><br />Hallo again,<br>see the attachement (marked up area) - I suppose I found the reason, why you cannot use FILLETEDGE wit a RADIUS greater than 10.8 - you'll get into geometrical problems.<br>Or you should try to find out non-circular-arc-based FILLET...<br>(Perhaps you could create a special filleting-tool for this - see the attachement in my first answer).<br>Regards<br>Jochen<br><br>www.ant-ares.de<a href="uploads/87494/Cloud-1.dwg" target="_blank" rel="nofollow">uploads/87494/Cloud-1.dwg</a><br>]]>
   <pubDate>Sat, 12 Aug 2017 22:47:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12433&amp;PID=35091&amp;title=help-3d#35091</guid>
   <title><![CDATA[HELP 3D : I have another idea. Maybe you...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12433&amp;PID=35084&amp;title=help-3d#35084</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 12433<br /><strong>Posted:</strong> 11.Aug.2017 at 18:22<br /><br />I have another idea. &nbsp;Maybe you can extrude two different shapes (the cloud being one), as solids, not surfaces, then run the INTERFERE command on them but do NOT delete the object that is created via the intersection of the two solids.<span style="font-size:10px"><br /><br />Edited by John Connor - 11.Aug.2017 at 18:22</span>]]>
   <pubDate>Fri, 11 Aug 2017 18:22:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12433&amp;PID=35084&amp;title=help-3d#35084</guid>
   <title><![CDATA[HELP 3D : Honestly, you don&amp;#039;t want...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12433&amp;PID=35083&amp;title=help-3d#35083</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 12433<br /><strong>Posted:</strong> 11.Aug.2017 at 16:52<br /><br />Honestly, you don't want to use the Fillet command. &nbsp;I think you would be better off making use of a mesh object that you can alter the vertices as needed to attain the shape you are looking for.]]>
   <pubDate>Fri, 11 Aug 2017 16:52:12 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12433&amp;PID=35083&amp;title=help-3d#35083</guid>
   <title><![CDATA[HELP 3D : yes, i already tried FILLET, but...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12433&amp;PID=35081&amp;title=help-3d#35081</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=585607">nmaia</a><br /><strong>Subject:</strong> 12433<br /><strong>Posted:</strong> 11.Aug.2017 at 13:35<br /><br />yes, i already tried FILLET, but is has a strange result:<br>Radius 5<br><a href="uploads/585607/Cloud1.dwg" target="_blank" rel="nofollow">uploads/585607/Cloud1.dwg</a><br>]]>
   <pubDate>Fri, 11 Aug 2017 13:35:29 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12433&amp;PID=35081&amp;title=help-3d#35081</guid>
   <title><![CDATA[HELP 3D : All scj did was use the FILLET...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12433&amp;PID=35079&amp;title=help-3d#35079</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 12433<br /><strong>Posted:</strong> 11.Aug.2017 at 11:53<br /><br />All scj did was use the FILLET command to put a radius on the edges which, if I understand you correctly, is not what you are trying to achieve.]]>
   <pubDate>Fri, 11 Aug 2017 11:53:08 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12433&amp;PID=35079&amp;title=help-3d#35079</guid>
   <title><![CDATA[HELP 3D : almost that...the curve should...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12433&amp;PID=35077&amp;title=help-3d#35077</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=585607">nmaia</a><br /><strong>Subject:</strong> 12433<br /><strong>Posted:</strong> 10.Aug.2017 at 15:34<br /><br />almost that...<div>the curve should be from top to bottom.</div><div>Plase tell me how to do it...</div>]]>
   <pubDate>Thu, 10 Aug 2017 15:34:40 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12433&amp;PID=35077&amp;title=help-3d#35077</guid>
   <title><![CDATA[HELP 3D : Perhaps something like this??u...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12433&amp;PID=35073&amp;title=help-3d#35073</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=87494">scj.schulz</a><br /><strong>Subject:</strong> 12433<br /><strong>Posted:</strong> 10.Aug.2017 at 13:44<br /><br />Perhaps something like this??<br><br><a href="uploads/87494/ABRUNDEN.dwg" target="_blank" rel="nofollow">uploads/87494/ABRUNDEN.dwg</a><br><br>Regards<br>Jochen<br><br>www.ant-ares.de<br><span style="font-size:10px"><br /><br />Edited by scj.schulz - 10.Aug.2017 at 13:47</span>]]>
   <pubDate>Thu, 10 Aug 2017 13:44:53 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12433&amp;PID=35073&amp;title=help-3d#35073</guid>
   <title><![CDATA[HELP 3D : Perhaps a mesh is what you should...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12433&amp;PID=35072&amp;title=help-3d#35072</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 12433<br /><strong>Posted:</strong> 10.Aug.2017 at 13:22<br /><br />Perhaps a mesh is what you should be working with.&nbsp; <br>]]>
   <pubDate>Thu, 10 Aug 2017 13:22:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12433&amp;PID=35072&amp;title=help-3d#35072</guid>
   <title><![CDATA[HELP 3D : sorry, don&amp;#039;t know how to...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12433&amp;PID=35069&amp;title=help-3d#35069</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=585607">nmaia</a><br /><strong>Subject:</strong> 12433<br /><strong>Posted:</strong> 10.Aug.2017 at 13:11<br /><br />sorry, don't know how to do it...]]>
   <pubDate>Thu, 10 Aug 2017 13:11:23 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12433&amp;PID=35069&amp;title=help-3d#35069</guid>
