  <title>CAD Forum discussion (EN) : Block Name Tool</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Block Name Tool]]></description>
  <pubDate>Tue, 03 Nov 2026 09:23:53 +0000</pubDate>
  <lastBuildDate>Wed, 08 Nov 2017 18:06:30 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=12509</WebWizForums:feedURL>
   <title><![CDATA[Block Name Tool :   MCCLARDK wrote: IS IT POSSIBLE...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12509&amp;PID=35298&amp;title=block-name-tool#35298</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=353260">Kent Cooper</a><br /><strong>Subject:</strong> 12509<br /><strong>Posted:</strong> 08.Nov.2017 at 18:06<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Originally posted by MCCLARDK" alt="Originally posted by MCCLARDK" style="vertical-align: text-bottom;" /> <strong>MCCLARDK wrote:</strong><br /><br />IS IT POSSIBLE TO USE A BLOCK WITH VISIBILITY PARAMATER INSIDE A MULTILEADER STYLE. I HAVE CREATED THE BLOCK WITH A VISIBILITY &amp; ATTACHED IT TO A MULTILEADER STYLE BUT WHEN I USE THE MULTILEADER STYLE I HAVE NO ACCESS TO THE VISIBILITY STATES UNLESS I EXPLODE THE MULTILEADER WHICH IS POINTLESS.</td></tr></table><div>&nbsp;</div><div>&#091;Does this have anything to do with the original question?&nbsp; Start a new topic.&#093;</div>]]>
   <pubDate>Wed, 08 Nov 2017 18:06:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12509&amp;PID=35298&amp;title=block-name-tool#35298</guid>
   <title><![CDATA[Block Name Tool :  IS IT POSSIBLE TO USE A BLOCK...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12509&amp;PID=35297&amp;title=block-name-tool#35297</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=631893">MCCLARDK</a><br /><strong>Subject:</strong> 12509<br /><strong>Posted:</strong> 08.Nov.2017 at 16:32<br /><br />IS IT POSSIBLE TO USE A BLOCK WITH VISIBILITY PARAMATER INSIDE A MULTILEADER STYLE. I HAVE CREATED THE BLOCK WITH A VISIBILITY &amp; ATTACHED IT TO A MULTILEADER STYLE BUT WHEN I USE THE MULTILEADER STYLE I HAVE NO ACCESS TO THE VISIBILITY STATES UNLESS I EXPLODE THE MULTILEADER WHICH IS POINTLESS.]]>
   <pubDate>Wed, 08 Nov 2017 16:32:12 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12509&amp;PID=35297&amp;title=block-name-tool#35297</guid>
   <title><![CDATA[Block Name Tool :  This is categorized in the AutoCAD...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12509&amp;PID=35286&amp;title=block-name-tool#35286</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=353260">Kent Cooper</a><br /><strong>Subject:</strong> 12509<br /><strong>Posted:</strong> 02.Nov.2017 at 16:43<br /><br />This is categorized in the AutoCAD Forum, but "definetag" is not a &#091;native&#093; AutoCAD command or function, as far as I'm aware.&nbsp; Your information also lists Revit -- is it a Revit function, and should this be in the Revit Forum instead?&nbsp; Or could it be a custom command you're using?&nbsp; If so, can you post the code that defines it?]]>
   <pubDate>Thu, 02 Nov 2017 16:43:29 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12509&amp;PID=35286&amp;title=block-name-tool#35286</guid>
   <title><![CDATA[Block Name Tool : I am trying to create a tool so...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12509&amp;PID=35277&amp;title=block-name-tool#35277</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=739285">mark_mjj</a><br /><strong>Subject:</strong> 12509<br /><strong>Posted:</strong> 31.Oct.2017 at 14:14<br /><br />I am trying to create a tool so that I can tag a Block Name. I have made this with definetag, but I can't make this with an arrow. Can anyone help me?]]>
   <pubDate>Tue, 31 Oct 2017 14:14:53 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12509&amp;PID=35277&amp;title=block-name-tool#35277</guid>
