  <title>CAD Forum discussion (EN) : Sheets</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : CAD - general : Sheets]]></description>
  <pubDate>Sat, 15 Aug 2026 04:58:24 +0000</pubDate>
  <lastBuildDate>Thu, 01 Mar 2018 16:40:16 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=12643</WebWizForums:feedURL>
   <title><![CDATA[Sheets : You can start with one of the...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12643&amp;PID=35718&amp;title=sheets#35718</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 12643<br /><strong>Posted:</strong> 01.Mar.2018 at 16:40<br /><br />You can start with one of the templates that comes with AutoCAD.<br><br>You are working in metric units correct?&nbsp; If so, then you want to use a metric based template file and not the default template file (acad.dwt) which uses imperial units.<br><br>Forum members have also uploaded their own versions of title block/border template files.&nbsp; Look in the CAD/BIM Blocks section under Architecture &gt; Templates.&nbsp; They may not be suited for civil work since layering conventions and scalelists might be different between different disciplines.<br><span style="font-size:10px"><br /><br />Edited by John Connor - 01.Mar.2018 at 16:43</span>]]>
   <pubDate>Thu, 01 Mar 2018 16:40:16 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12643&amp;PID=35718&amp;title=sheets#35718</guid>
   <title><![CDATA[Sheets : Where is the best place to start...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12643&amp;PID=35717&amp;title=sheets#35717</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=742154">Davemagpie</a><br /><strong>Subject:</strong> 12643<br /><strong>Posted:</strong> 01.Mar.2018 at 16:10<br /><br />Where is the best place to start <br />]]>
   <pubDate>Thu, 01 Mar 2018 16:10:16 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12643&amp;PID=35717&amp;title=sheets#35717</guid>
   <title><![CDATA[Sheets : If you don&amp;#039;t like any of...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12643&amp;PID=35716&amp;title=sheets#35716</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 12643<br /><strong>Posted:</strong> 01.Mar.2018 at 15:52<br /><br />If you don't like any of the templates that come shipped with AutoCAD you can always create your own.&nbsp; The advantage is you can preset content and customize settings to suit your needs.<br>]]>
   <pubDate>Thu, 01 Mar 2018 15:52:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12643&amp;PID=35716&amp;title=sheets#35716</guid>
   <title><![CDATA[Sheets : Yes John I am ]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12643&amp;PID=35715&amp;title=sheets#35715</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=742154">Davemagpie</a><br /><strong>Subject:</strong> 12643<br /><strong>Posted:</strong> 01.Mar.2018 at 14:44<br /><br />Yes John I am<br />]]>
   <pubDate>Thu, 01 Mar 2018 14:44:51 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12643&amp;PID=35715&amp;title=sheets#35715</guid>
   <title><![CDATA[Sheets : Could you be referring to a drawing...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12643&amp;PID=35714&amp;title=sheets#35714</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 12643<br /><strong>Posted:</strong> 01.Mar.2018 at 14:32<br /><br />Could you be referring to a drawing template with title block and border by any chance?&nbsp; <br>]]>
   <pubDate>Thu, 01 Mar 2018 14:32:02 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12643&amp;PID=35714&amp;title=sheets#35714</guid>
   <title><![CDATA[Sheets : I am new to AutoCAD, Where can...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12643&amp;PID=35713&amp;title=sheets#35713</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=742154">Davemagpie</a><br /><strong>Subject:</strong> 12643<br /><strong>Posted:</strong> 01.Mar.2018 at 14:17<br /><br />I am new to AutoCAD, <br />Where can I get different sheet sets I would like a sheet set with all the information on the bottom of the A3 paper as a pose to the sides. Does anyone have such a sheet dwt I have manufacturing architectural and civil.<br /><br />Can anyone help or can I do my own and save it.<br /><br />Thanks in advance<br /><br />David]]>
   <pubDate>Thu, 01 Mar 2018 14:17:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12643&amp;PID=35713&amp;title=sheets#35713</guid>
