  <title>CAD Forum discussion (EN) : AutoCAD data can&#039;t be opened</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : AutoCAD data can&#039;t be opened]]></description>
  <pubDate>Thu, 05 Nov 2026 06:54:37 +0000</pubDate>
  <lastBuildDate>Fri, 30 Mar 2018 00:51:04 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=12681</WebWizForums:feedURL>
   <title><![CDATA[AutoCAD data can&#039;t be opened : Did you or someone else open the...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12681&amp;PID=35852&amp;title=autocad-data-cant-be-opened#35852</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 12681<br /><strong>Posted:</strong> 30.Mar.2018 at 00:51<br /><br />Did you or someone else open the drawing in an AutoCAD clone such as Draftsight or Bricscad then save it?<div><br></div><div>Is there a .BAK file available?</div><div><br></div><div>Did you try using the RECOVER command?</div><span style="font-size:10px"><br /><br />Edited by John Connor - 30.Mar.2018 at 00:53</span>]]>
   <pubDate>Fri, 30 Mar 2018 00:51:04 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12681&amp;PID=35852&amp;title=autocad-data-cant-be-opened#35852</guid>
   <title><![CDATA[AutoCAD data can&#039;t be opened : My processed .dwg file stopped...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12681&amp;PID=35851&amp;title=autocad-data-cant-be-opened#35851</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=771515">elsiebutler</a><br /><strong>Subject:</strong> 12681<br /><strong>Posted:</strong> 30.Mar.2018 at 00:16<br /><br /><p ="MsoNormal" style="line-height:150%"><span lang="EN-US" style="font-size: 14pt; line-height: 150%;"><font face="Georgia, Times New Roman, Times, serif">My processed .dwg file stopped opening since yesterday. Now when I tryto open it see Non Autodesk DWG file. I'm using AutoCAD 2016 on Windows 8.1x64. I hope someone could assist.</font><font face="Times New Roman, serif"><o:p></o:p></font></span></p>]]>
   <pubDate>Fri, 30 Mar 2018 00:16:47 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12681&amp;PID=35851&amp;title=autocad-data-cant-be-opened#35851</guid>
