  <title>CAD Forum discussion (EN) : XCLIPPING</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : Civil 3D, Map, InfraWorks : XCLIPPING]]></description>
  <pubDate>Thu, 15 Oct 2026 16:17:59 +0000</pubDate>
  <lastBuildDate>Mon, 25 Jun 2018 05:19:01 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=12763</WebWizForums:feedURL>
   <title><![CDATA[XCLIPPING :  My question is a 2 part question.I...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12763&amp;PID=36092&amp;title=xclipping#36092</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=780568">abustraan</a><br /><strong>Subject:</strong> 12763<br /><strong>Posted:</strong> 25.Jun.2018 at 05:19<br /><br />My question is a 2 part question.<div>&nbsp;</div><div>I have a drawing that when plotted to PDF it "flattens" when plotted and pretty much locks up at 28% or 43%. There are no "transparent" blocks, layers, etc.</div><div>&nbsp;</div><div>However, there are 4 xclipped external references. I have successfully bound the external references. so I have a standalone drawing. However, the XCLIP's remain.</div><div>&nbsp;</div><div>Other information:</div><div>Tried AutoCAD 2018/2019, Civil 3D AECtoAcad to remove any&nbsp;AEC objects. </div><div>If I use DWG to PDF&nbsp;the resulting PDF&nbsp;2,059 KB, and if I use Bluebeam its 3,143 KB. The Cad file is 2,097 KB.&nbsp;</div><div>&nbsp;</div><div>My questions are:</div><div>&nbsp;</div><div>Could XCLIPS cause the drawing to require "flattening"</div><div>Can the XCLIPPED information be trimmed and removed?</div><div>&nbsp;</div><div>Thanks in advance.</div><div>&nbsp;</div>]]>
   <pubDate>Mon, 25 Jun 2018 05:19:01 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12763&amp;PID=36092&amp;title=xclipping#36092</guid>
