  <title>CAD Forum discussion (EN) : Modifying 3D objects</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Modifying 3D objects]]></description>
  <pubDate>Fri, 30 Oct 2026 19:22:39 +0000</pubDate>
  <lastBuildDate>Tue, 14 Aug 2018 18:21:03 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=12794</WebWizForums:feedURL>
   <title><![CDATA[Modifying 3D objects : You could try using the Move Face...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12794&amp;PID=36167&amp;title=modifying-3d-objects#36167</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 12794<br /><strong>Posted:</strong> 14.Aug.2018 at 18:21<br /><br />You could try using the Move Face command.<div><br></div><div>Changes to a 3D object can be made with any of the 3D Solid Editing commands such as...</div><div><br></div><div>Union</div><div>Subtract</div><div>Intersect</div><div>Slice</div><div>Imprint</div><div>Move Faces</div><div>Extrude Faces</div><div>Taper, Copy, Offset, Delete, etc. Faces</div><div>Extract or Copy Edges</div><div><br></div><div>Just to name a few.</div><div><br></div><div><br></div><div><br></div><span style="font-size:10px"><br /><br />Edited by John Connor - 14.Aug.2018 at 18:22</span>]]>
   <pubDate>Tue, 14 Aug 2018 18:21:03 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12794&amp;PID=36167&amp;title=modifying-3d-objects#36167</guid>
   <title><![CDATA[Modifying 3D objects : I&amp;#039;m all new to this. How...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12794&amp;PID=36165&amp;title=modifying-3d-objects#36165</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=785858">gergo77</a><br /><strong>Subject:</strong> 12794<br /><strong>Posted:</strong> 14.Aug.2018 at 14:09<br /><br />I'm all new to this. How do I modify the thickness of a cylinder? And how do I make slight alterations to a 3D object in general?<br>]]>
   <pubDate>Tue, 14 Aug 2018 14:09:47 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12794&amp;PID=36165&amp;title=modifying-3d-objects#36165</guid>
