  <title>CAD Forum discussion (EN) : Text Hight Adustment</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Text Hight Adustment]]></description>
  <pubDate>Fri, 04 Sep 2026 23:52:23 +0000</pubDate>
  <lastBuildDate>Wed, 12 Nov 2008 11:12:32 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=1304</WebWizForums:feedURL>
   <title><![CDATA[Text Hight Adustment : ?Are you saying you want your...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1304&amp;PID=3561&amp;title=text-hight-adustment#3561</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=22753">rossassociates</a><br /><strong>Subject:</strong> 1304<br /><strong>Posted:</strong> 12.Nov.2008 at 11:12<br /><br />?<br><br>Are you saying you want your text to be the same height, irrespective of scale on the drawing?<br><br>You have two choices...<br><br>1) create a number of different text styles and simply multiply the height of the text from a "base" scale, say 1:100...&nbsp; so you have TXT100, TXT200, TXT300, TXT500, TXT1000...&nbsp; If TXT100 text is 20 "high", then TXT200 is 40, TXT300 is 60, TXT500 is 100 and TXT1000 is 200, etc..<br><br>or<br><br>2) Create the text on the Layout tab, not model tab...<br><br>There are pros and cons to both..&nbsp; We use number 1) above, but I guess it depends on how many different scales you have on your drawings..&nbsp; Although saying that, we mix it up with some text on the layout tab, but that is for our notes only.<br><br>HTH<br><br>]]>
   <pubDate>Wed, 12 Nov 2008 11:12:32 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1304&amp;PID=3561&amp;title=text-hight-adustment#3561</guid>
   <title><![CDATA[Text Hight Adustment : Hi  i want toAdustment of Text...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1304&amp;PID=3554&amp;title=text-hight-adustment#3554</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=1984">tariq</a><br /><strong>Subject:</strong> 1304<br /><strong>Posted:</strong> 11.Nov.2008 at 09:09<br /><br />Hi<DIV>&nbsp;</DIV><DIV>i want to&nbsp;Adustment of Text hight. So i want to know whats scale factor of while i work in mm plz advice me &nbsp;</DIV><DIV></DIV>]]>
   <pubDate>Tue, 11 Nov 2008 09:09:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1304&amp;PID=3554&amp;title=text-hight-adustment#3554</guid>
