  <title>CAD Forum discussion (EN) : Explode attributes block</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Explode attributes block]]></description>
  <pubDate>Mon, 26 Oct 2026 22:56:34 +0000</pubDate>
  <lastBuildDate>Tue, 15 Jan 2019 07:12:03 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=13058</WebWizForums:feedURL>
   <title><![CDATA[Explode attributes block : Hello ncespedes and Kent, I will...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13058&amp;PID=36672&amp;title=explode-attributes-block#36672</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=175428">philippe JOSEPH</a><br /><strong>Subject:</strong> 13058<br /><strong>Posted:</strong> 15.Jan.2019 at 07:12<br /><br /><span style="color: rgb54, 69, 90; font-size: small; : rgb247, 247, 249;">Hello ncespedes and Kent, I will take a look at your solution because when we had this problem the solution that we had was the one that I have described ( and the only one that we found by ourselves ).</span><div><span style="color: rgb54, 69, 90; font-size: small; : rgb247, 247, 249;">As it was working like no other one found here in CAD Forum or else were we've stoped the searches.</span></div>]]>
   <pubDate>Tue, 15 Jan 2019 07:12:03 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13058&amp;PID=36672&amp;title=explode-attributes-block#36672</guid>
   <title><![CDATA[Explode attributes block : Kent, I was able to find it, I...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13058&amp;PID=36671&amp;title=explode-attributes-block#36671</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=191872">ncespedes</a><br /><strong>Subject:</strong> 13058<br /><strong>Posted:</strong> 14.Jan.2019 at 15:51<br /><br />Kent, I was able to find it, I had to be in the Block Editor and then look in the Properties Palette. Now I can explode using the Attributes Explode and get what I want. The good thing about this is that it will change all other blocks in the dwg and this is exactly what I wanted, thanks.<div><br></div><div>Have a Happy New Year!</div><div><br></div><div>Joseph, thank you anyway.</div>]]>
   <pubDate>Mon, 14 Jan 2019 15:51:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13058&amp;PID=36671&amp;title=explode-attributes-block#36671</guid>
   <title><![CDATA[Explode attributes block : Hello ncespedes and Kent, I suppose...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13058&amp;PID=36663&amp;title=explode-attributes-block#36663</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=175428">philippe JOSEPH</a><br /><strong>Subject:</strong> 13058<br /><strong>Posted:</strong> 12.Jan.2019 at 20:58<br /><br />Hello ncespedes and Kent, I suppose that you want to explode this block to NCOPY lines, arcs and/or other elements inside it. Maybe this is not possible because the block was contituted without the possibility to explode it so you can't NCOPY elements.<div>There is a possibility to NCOPY anyway by doing this :</div><div>REFEDIT the block to enter inside it, do a copy of the entire block or the elements that you want to copy, select these elements and press on the minus button ( - ) to take them out of the block and close the refedit.&nbsp;</div><div>Then you can eventually rebuilt an editable block in the old way with the same name and insertion point for it to be correctly updated in your file(s).&nbsp;</div><span style="font-size:10px"><br /><br />Edited by philippe JOSEPH - 12.Jan.2019 at 21:01</span>]]>
   <pubDate>Sat, 12 Jan 2019 20:58:46 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13058&amp;PID=36663&amp;title=explode-attributes-block#36663</guid>
   <title><![CDATA[Explode attributes block :  Do you not see this?That Block...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13058&amp;PID=36661&amp;title=explode-attributes-block#36661</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=353260">Kent Cooper</a><br /><strong>Subject:</strong> 13058<br /><strong>Posted:</strong> 11.Jan.2019 at 22:49<br /><br />Do you not see this?<div><img src="uploads/353260/BlockExplode.PNG" height="148" width="188" border="0" /></div><div>That Block category is at the bottom of the Properties palette.&nbsp; You have to be <em>in the Block Editor</em> editing the Block in question, not just have an insertion of it selected in the generic Properties palette.</div><span style="font-size:10px"><br /><br />Edited by Kent Cooper - 11.Jan.2019 at 22:49</span>]]>
   <pubDate>Fri, 11 Jan 2019 22:49:19 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13058&amp;PID=36661&amp;title=explode-attributes-block#36661</guid>
   <title><![CDATA[Explode attributes block : Kent, thank you for your response.Explode...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13058&amp;PID=36660&amp;title=explode-attributes-block#36660</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=191872">ncespedes</a><br /><strong>Subject:</strong> 13058<br /><strong>Posted:</strong> 11.Jan.2019 at 22:13<br /><br />Kent, thank you for your response.<div>Explode does not work, neither from icon nor typing. It may be defined as not to allow exploding, but I don't know where to find the yes or no choices.&nbsp; The properties palette does not show it. I'm working with Autocad 2019.&nbsp;</div>]]>
   <pubDate>Fri, 11 Jan 2019 22:13:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13058&amp;PID=36660&amp;title=explode-attributes-block#36660</guid>
   <title><![CDATA[Explode attributes block :  I&amp;#039;m not sure what you mean...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13058&amp;PID=36659&amp;title=explode-attributes-block#36659</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=353260">Kent Cooper</a><br /><strong>Subject:</strong> 13058<br /><strong>Posted:</strong> 11.Jan.2019 at 19:12<br /><br />I'm not sure what you mean by "shows as Enhanced Attribute Editor."&nbsp; That comes up if you double-click on a Block containing Attributes, but double-clicking on one would not be the way to Explode it, and that Editor has nothing to do with whether it can be Exploded or not.<div></div><div>If you want to Explode it, select it &#091;single-click&#093;,&nbsp;then either&nbsp;pick the Explode icon in the Modify section of the Home ribbon, or type in EXPLODE.&nbsp; Or do it in the other order &#091;command first, then selection&#093;.&nbsp; If it won't let you, the Block has been defined to not allow Exploding.&nbsp; You can change that by calling up the BEDIT command, which you can do with a Block without Attributes by double-cliking on it -- maybe that's the issue, that one with Attributes doesn't work that way.&nbsp; But you can select it &#091;single-click&#093;, right-click and pick Block Editor.</div><div>&nbsp;</div><div>If you don't have the Properties palette up already, type PROPERTIES.&nbsp; In the Block category there is a line for&nbsp;"Allow exploding" with Yes and No choices.&nbsp; But consider carefully whether there's a <em>reason</em> it was defined to not allow Exploding, because you're changing not just the selected Block but the Block definition --&nbsp;if you change it from No to Yes, it won't just let you Explode that <em>one</em>, but the protection provided to <em>all other</em> Insertions of the same Block will be lost.</div>]]>
   <pubDate>Fri, 11 Jan 2019 19:12:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13058&amp;PID=36659&amp;title=explode-attributes-block#36659</guid>
   <title><![CDATA[Explode attributes block : I can&amp;#039;t explode a block that...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13058&amp;PID=36657&amp;title=explode-attributes-block#36657</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=191872">ncespedes</a><br /><strong>Subject:</strong> 13058<br /><strong>Posted:</strong> 11.Jan.2019 at 17:16<br /><br />I can't explode a block that shows as Enhanced Attribute Editor.]]>
   <pubDate>Fri, 11 Jan 2019 17:16:42 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13058&amp;PID=36657&amp;title=explode-attributes-block#36657</guid>
