  <title>CAD Forum discussion (EN) : Construction Lines</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Construction Lines]]></description>
  <pubDate>Fri, 30 Oct 2026 08:45:21 +0000</pubDate>
  <lastBuildDate>Fri, 08 Feb 2019 22:34:39 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=13091</WebWizForums:feedURL>
   <title><![CDATA[Construction Lines :   cavemaned wrote:It&amp;#039;s the...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13091&amp;PID=36751&amp;title=construction-lines#36751</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=353260">Kent Cooper</a><br /><strong>Subject:</strong> 13091<br /><strong>Posted:</strong> 08.Feb.2019 at 22:34<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Originally posted by cavemaned" alt="Originally posted by cavemaned" style="vertical-align: text-bottom;" /> <strong>cavemaned wrote:</strong><br /><br />It's the Draw Construction Lines command AMCONSTLINES. ....</td></tr></table><div></div><div></div>That's not a base AutoCAD command.&nbsp; From the AM part I assume you're using AutoCAD Mechanical.&nbsp; If so, I can't help you, but can you re-install that part, not just the underlying AutoCAD &#091;if that's even how it works....&#093;?]]>
   <pubDate>Fri, 08 Feb 2019 22:34:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13091&amp;PID=36751&amp;title=construction-lines#36751</guid>
   <title><![CDATA[Construction Lines : It brings up the dialog box, lets...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13091&amp;PID=36750&amp;title=construction-lines#36750</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=169606">cavemaned</a><br /><strong>Subject:</strong> 13091<br /><strong>Posted:</strong> 08.Feb.2019 at 19:27<br /><br />It brings up the dialog box, lets me select a function, but when I go to place the line there's nothing.<span style="font-size:10px"><br /><br />Edited by cavemaned - 08.Feb.2019 at 19:27</span>]]>
   <pubDate>Fri, 08 Feb 2019 19:27:16 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13091&amp;PID=36750&amp;title=construction-lines#36750</guid>
   <title><![CDATA[Construction Lines : It&amp;#039;s the Draw Construction...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13091&amp;PID=36749&amp;title=construction-lines#36749</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=169606">cavemaned</a><br /><strong>Subject:</strong> 13091<br /><strong>Posted:</strong> 08.Feb.2019 at 19:24<br /><br />It's the Draw Construction Lines command AMCONSTLINES. It creates a new layer and has a feature where you can delete all of them at once, etc. The other commands work fine. I was using it in the beginning of the project, now it won't work at all. I have even re-installed AutoCAD since the problem began due to other issues. Still doesn't work. It's <i>that</i> drawing only.]]>
   <pubDate>Fri, 08 Feb 2019 19:24:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13091&amp;PID=36749&amp;title=construction-lines#36749</guid>
   <title><![CDATA[Construction Lines :  Can you draw other things normally?...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13091&amp;PID=36748&amp;title=construction-lines#36748</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=353260">Kent Cooper</a><br /><strong>Subject:</strong> 13091<br /><strong>Posted:</strong> 08.Feb.2019 at 18:52<br /><br />Can you draw other things normally?&nbsp; It is possible for the <em>current Layer to be turned off</em>, or for the <em>current entity color to be the same as the background color</em>, but if either of those is the reason, you wouldn't see anything else that you draw, either&nbsp;(in some commands you'll see the object during the construction of it, but it will disappear once the command is completed).<div>&nbsp;</div><div>If that's not the issue, is it just XLINEs?&nbsp; Also RAYs &#091;the <em>one</em>-ended form of Construction lines&#093;?&nbsp; Anything else you can identify?</div>]]>
   <pubDate>Fri, 08 Feb 2019 18:52:28 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13091&amp;PID=36748&amp;title=construction-lines#36748</guid>
   <title><![CDATA[Construction Lines : Suddenly, I can&amp;#039;t draw construction...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13091&amp;PID=36746&amp;title=construction-lines#36746</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=169606">cavemaned</a><br /><strong>Subject:</strong> 13091<br /><strong>Posted:</strong> 08.Feb.2019 at 15:29<br /><br />Suddenly, I can't draw construction lines. If I open a new drawing I can, but this one suddenly stopped letting me draw them.]]>
   <pubDate>Fri, 08 Feb 2019 15:29:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13091&amp;PID=36746&amp;title=construction-lines#36746</guid>
