  <title>CAD Forum discussion (EN) : Xref selected Layers</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Xref selected Layers]]></description>
  <pubDate>Fri, 17 Jul 2026 11:57:40 +0000</pubDate>
  <lastBuildDate>Wed, 28 Aug 2019 08:24:48 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=13252</WebWizForums:feedURL>
   <title><![CDATA[Xref selected Layers : Hello domnanan, AutoCAD gives...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13252&amp;PID=37117&amp;title=xref-selected-layers#37117</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=175428">philippe JOSEPH</a><br /><strong>Subject:</strong> 13252<br /><strong>Posted:</strong> 28.Aug.2019 at 08:24<br /><br />Hello domnanan, AutoCAD gives the possibility to switch from "all in the file" to Wblock or Xref and you can also switch back to the contrary like for example Xref to classic internal blocks or anything that you want.<div>This is not possible on any other software.</div><span style="font-size:10px"><br /><br />Edited by philippe JOSEPH - 28.Aug.2019 at 14:55</span>]]>
   <pubDate>Wed, 28 Aug 2019 08:24:48 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13252&amp;PID=37117&amp;title=xref-selected-layers#37117</guid>
   <title><![CDATA[Xref selected Layers : I see that you well understood...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13252&amp;PID=37116&amp;title=xref-selected-layers#37116</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=22968">domnanan</a><br /><strong>Subject:</strong> 13252<br /><strong>Posted:</strong> 27.Aug.2019 at 23:19<br /><br />I see that you well understood what I meant.<br />I just feel that this could be done automatically.<br />May be in future version. <img src="https://www.cadforum.cz/forum_en/smileys/smiley2.gif" border="0" align="middle" /> ]]>
   <pubDate>Tue, 27 Aug 2019 23:19:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13252&amp;PID=37116&amp;title=xref-selected-layers#37116</guid>
   <title><![CDATA[Xref selected Layers :  You can use QSELECT to select...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13252&amp;PID=37113&amp;title=xref-selected-layers#37113</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 13252<br /><strong>Posted:</strong> 27.Aug.2019 at 07:59<br /><br />You can use QSELECT to select object on a particular layer and then WBLOCK them to a separate DWG file. This can be the XREFed to the main drawing.]]>
   <pubDate>Tue, 27 Aug 2019 07:59:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13252&amp;PID=37113&amp;title=xref-selected-layers#37113</guid>
   <title><![CDATA[Xref selected Layers : Hi Acad Forumist,I&amp;#039;m just...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13252&amp;PID=37081&amp;title=xref-selected-layers#37081</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=22968">domnanan</a><br /><strong>Subject:</strong> 13252<br /><strong>Posted:</strong> 03.Aug.2019 at 11:16<br /><br />Hi Acad Forumist,<br /><br />I'm just wondering weather we can  partially extract some layers from a drawing to attach the latter into another one as and external reference. <br /><br />Lets say that I want to extract only 'Roof' layer from my 'villa' drawing to a site plan. Any change in the roof layer would at my source would reflect to the site plan. On the site plan other layers would be cumbersome.  <br /> <br />What do u think?  <img src="https://www.cadforum.cz/forum_en/smileys/smiley2.gif" border="0" align="middle" /> ]]>
   <pubDate>Sat, 03 Aug 2019 11:16:06 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13252&amp;PID=37081&amp;title=xref-selected-layers#37081</guid>
