  <title>CAD Forum discussion (EN) : Hatch</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : CAD - general : Hatch]]></description>
  <pubDate>Mon, 14 Sep 2026 21:13:12 +0000</pubDate>
  <lastBuildDate>Fri, 27 Sep 2019 23:38:19 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=13293</WebWizForums:feedURL>
   <title><![CDATA[Hatch : Thanks for responding, I already...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13293&amp;PID=37164&amp;title=hatch#37164</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=208841">luisfernandez</a><br /><strong>Subject:</strong> 13293<br /><strong>Posted:</strong> 27.Sep.2019 at 23:38<br /><br />Thanks for responding, I already took care , concrete walls and I use 135 degrees, and the lines were horizontal in the vertical wall]]>
   <pubDate>Fri, 27 Sep 2019 23:38:19 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13293&amp;PID=37164&amp;title=hatch#37164</guid>
   <title><![CDATA[Hatch :   luisfernandez wrote:.... which...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13293&amp;PID=37163&amp;title=hatch#37163</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=353260">Kent Cooper</a><br /><strong>Subject:</strong> 13293<br /><strong>Posted:</strong> 27.Sep.2019 at 18:23<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Originally posted by luisfernandez" alt="Originally posted by luisfernandez" style="vertical-align: text-bottom;" /> <strong>luisfernandez wrote:</strong><br /><br />.... which angle you use for the vertical ection of the wall to be horizontal ansi 31</td></tr></table><div><br></div><div>The ANSI31 pattern draws its lines at a "native" angle of 45 degrees, so if you want them horizontal, use the pattern at a rotation of 135 or 315 degrees.</div><div><br></div><div>But better yet, don't use ANSI31!&nbsp; Use the <b>U</b>ser-defined option.&nbsp; Then you can just tell it <i>directly</i> not only what direction you want the lines to run, but also <i>how far apart</i> -- no need to figure out a scale to apply to an ANSI31 Hatch to get the line spacing you want.</div>]]>
   <pubDate>Fri, 27 Sep 2019 18:23:59 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13293&amp;PID=37163&amp;title=hatch#37163</guid>
   <title><![CDATA[Hatch : Why are hatching a wall (architctural)...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13293&amp;PID=37157&amp;title=hatch#37157</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 13293<br /><strong>Posted:</strong> 26.Sep.2019 at 13:32<br /><br />Why are hatching a wall (architctural) with a hatch pattern more associated with metal?&nbsp; What kind of wall is it?&nbsp; Concrete?&nbsp; Brick? &nbsp;]]>
   <pubDate>Thu, 26 Sep 2019 13:32:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13293&amp;PID=37157&amp;title=hatch#37157</guid>
   <title><![CDATA[Hatch : IM trying to hatch a wall, vertical...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13293&amp;PID=37155&amp;title=hatch#37155</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=208841">luisfernandez</a><br /><strong>Subject:</strong> 13293<br /><strong>Posted:</strong> 26.Sep.2019 at 00:19<br /><br />IM trying to hatch a wall, vertical and already did the horizontal with angle 45, which angle you use for the vertical ection of the wall to be horizontal ansi 31]]>
   <pubDate>Thu, 26 Sep 2019 00:19:59 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13293&amp;PID=37155&amp;title=hatch#37155</guid>
