  <title>CAD Forum discussion (EN) : STICK SEPARATE HATCHES BACK TOGETHER</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : STICK SEPARATE HATCHES BACK TOGETHER]]></description>
  <pubDate>Sat, 05 Sep 2026 05:42:34 +0000</pubDate>
  <lastBuildDate>Mon, 01 Dec 2008 10:23:29 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=1331</WebWizForums:feedURL>
   <title><![CDATA[STICK SEPARATE HATCHES BACK TOGETHER : creating a block as you suppose...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1331&amp;PID=3791&amp;title=stick-separate-hatches-back-together#3791</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=26447">jansens</a><br /><strong>Subject:</strong> 1331<br /><strong>Posted:</strong> 01.Dec.2008 at 10:23<br /><br /><P>creating a block as you suppose would only be a temporary &amp; rather not suggested solution as it would add unecessary block definitions, and the resulting object would not be editable with Hatchedit (as it wouldn't be a Hatch any more) Moreover if you exploded the block-hatch it would return directly to previous status.(leaving the definition behind / purge etc).If we were to stick hatches together in this way,I would suggest creating groups that are by far more flexible than blocks in these types of actions.</P><DIV>Anyway, what I asked for was about the way to create a single hatch object by sticking together hatches of exactly the same properties.(as if it were created by a single hatch command session with the "create separate hatches" option deselected.</DIV><DIV>&nbsp;</DIV><DIV>thanks.</DIV>]]>
   <pubDate>Mon, 01 Dec 2008 10:23:29 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1331&amp;PID=3791&amp;title=stick-separate-hatches-back-together#3791</guid>
   <title><![CDATA[STICK SEPARATE HATCHES BACK TOGETHER : Hi, I think, we canstick back...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1331&amp;PID=3790&amp;title=stick-separate-hatches-back-together#3790</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=2359">Rman</a><br /><strong>Subject:</strong> 1331<br /><strong>Posted:</strong> 01.Dec.2008 at 02:40<br /><br /><P>Hi,</P><DIV>I think, we can&nbsp;stick back all the hatches&nbsp;grouping&nbsp;together by making them a 'block'. Lets try &gt; Draw&gt;Block&gt;Make..</DIV><DIV>&nbsp;</DIV><DIV>hth, thanks.</DIV><DIV>Rman.</DIV><DIV>Autocad 2005, LDD 2005</DIV>]]>
   <pubDate>Mon, 01 Dec 2008 02:40:53 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1331&amp;PID=3790&amp;title=stick-separate-hatches-back-together#3790</guid>
   <title><![CDATA[STICK SEPARATE HATCHES BACK TOGETHER : I know that it is possible to...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1331&amp;PID=3632&amp;title=stick-separate-hatches-back-together#3632</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=26447">jansens</a><br /><strong>Subject:</strong> 1331<br /><strong>Posted:</strong> 18.Nov.2008 at 08:53<br /><br />I know that it is possible to separate a complex hatch object (that was defined by multiple boundaries and objects<BR>in a single hatch command session) with the Hatchedit command and the setting for "separate hatches" activated.<BR>What if we have created some hatch objects (in a single hatch command session by clicking into various boundaries)<BR>with the setting to "create separate hatches" activated by mistake? Is it in some way possible to stick all the<BR>separate hatches back together in a single hatch object (without deleting them &amp; placing hatch from scratch)? ]]>
   <pubDate>Tue, 18 Nov 2008 08:53:14 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1331&amp;PID=3632&amp;title=stick-separate-hatches-back-together#3632</guid>
