  <title>CAD Forum discussion (EN) : Lines slightly elevated, can&#039;t flatten</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Lines slightly elevated, can&#039;t flatten]]></description>
  <pubDate>Sat, 05 Sep 2026 01:07:39 +0000</pubDate>
  <lastBuildDate>Wed, 05 Feb 2020 12:50:48 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=13370</WebWizForums:feedURL>
   <title><![CDATA[Lines slightly elevated, can&#039;t flatten :  Hi KarolTo increase the precision...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13370&amp;PID=37409&amp;title=lines-slightly-elevated-cant-flatten#37409</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=545332">BigSid</a><br /><strong>Subject:</strong> 13370<br /><strong>Posted:</strong> 05.Feb.2020 at 12:50<br /><br />Hi Karol<div>&nbsp;</div><div><div>To increase the precision change&nbsp;UNITS to Scientific.</div></div><div>To make the lines to z=0; select the line then in the Properties Dialogue change Z-Coordinate to 1 then change back to 0.</div><div>&nbsp;</div><div>&nbsp;</div>]]>
   <pubDate>Wed, 05 Feb 2020 12:50:48 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13370&amp;PID=37409&amp;title=lines-slightly-elevated-cant-flatten#37409</guid>
   <title><![CDATA[Lines slightly elevated, can&#039;t flatten : What command are you using to...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13370&amp;PID=37402&amp;title=lines-slightly-elevated-cant-flatten#37402</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 13370<br /><strong>Posted:</strong> 31.Jan.2020 at 13:38<br /><br /><div><font size="2">What command are you using to obtain the Z coordinate <span style="text-align: left; color: rgb54, 69, 90; text-trans: none; text-indent: 0px; letter-spacing: normal; font-family: Verdana,Arial,Helvetica,sans-serif; font-style: normal; font-variant: normal; font-weight: 400; text-decoration: none; word-spacing: 0px; display: inline !imant; white-space: normal; orphans: 2; : none; -webkit-text-stroke-width: 0px; : rgb247, 247, 249;">0.0000000068</span>?&nbsp;</font></div><div><font size="2"><br></font></div><div><font size="2">Couldn't you just erase the offending line(s) and redraw them with a Z of 0.00000000000?</font></div><span style="font-size:10px"><br /><br />Edited by John Connor - 31.Jan.2020 at 18:41</span>]]>
   <pubDate>Fri, 31 Jan 2020 13:38:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13370&amp;PID=37402&amp;title=lines-slightly-elevated-cant-flatten#37402</guid>
   <title><![CDATA[Lines slightly elevated, can&#039;t flatten : I try to make a block, the insertion...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13370&amp;PID=37400&amp;title=lines-slightly-elevated-cant-flatten#37400</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=302330">KarolR</a><br /><strong>Subject:</strong> 13370<br /><strong>Posted:</strong> 31.Jan.2020 at 04:56<br /><br /><div>I try to make a block, the insertion point is the corner inside the red circle.</div><div>The z coordinate shows something like 0.0000000068</div><div>The smallest precision in the UNITS control is less: 0.00000000, so it doesn't help.</div><div>Thus the ID command shoes only 0.00000000</div><div>FLATTEN causes troubles, it destroyes some of the shapes that have the same characteristics.</div><div>CHANGE--&gt;Elev shows O.K.: 0.00000000</div><div><a href="uploads/302330/Question.dwg" target="_blank" rel="nofollow">uploads/302330/Question.dwg</a><br></div>]]>
   <pubDate>Fri, 31 Jan 2020 04:56:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13370&amp;PID=37400&amp;title=lines-slightly-elevated-cant-flatten#37400</guid>
