  <title>CAD Forum discussion (EN) : New to CAD need help</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : New to CAD need help]]></description>
  <pubDate>Sun, 24 May 2026 21:58:45 +0000</pubDate>
  <lastBuildDate>Thu, 26 Mar 2020 11:40:29 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=13398</WebWizForums:feedURL>
   <title><![CDATA[New to CAD need help : Use the Dimension tools located...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13398&amp;PID=37488&amp;title=new-to-cad-need-help#37488</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 13398<br /><strong>Posted:</strong> 26.Mar.2020 at 11:40<br /><br />Use the Dimension tools located in the Ribbon at the top of your screen.&nbsp; For a good tutorial on the topic go to www.mycadsite.com.&nbsp; When you get to the first page click on Tutorials.&nbsp; Scroll down the page and find the section labeled: CAD Level One - Getting Started With AutoCAD.&nbsp; Find and click on Lesson 1-8: Assignment 6 (Layers Dimensions Text Scale).&nbsp; Finally, at the next page scroll down until you get to the section that is labeled: Dimensioning in AutoCAD.]]>
   <pubDate>Thu, 26 Mar 2020 11:40:29 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13398&amp;PID=37488&amp;title=new-to-cad-need-help#37488</guid>
   <title><![CDATA[New to CAD need help : Hello stefanerickson, when you...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13398&amp;PID=37487&amp;title=new-to-cad-need-help#37487</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=175428">philippe JOSEPH</a><br /><strong>Subject:</strong> 13398<br /><strong>Posted:</strong> 26.Mar.2020 at 08:30<br /><br />Hello stefanerickson, when you draw a piece you should place the necessary dimensions for it to be fabricated and not use the "measuring tool" all the time.<div>You should use the commands : DIMLINEAR , DIMALI , DIMRADIUS , DIMDIAMETER , DIMANGULAR , etc... and leave these dimensions in place that you can modify/update easily with TRIM for example.</div><div>If you have had a technical curse you should know that you have to place first the 3 main dimensions Length x Width x Thickness + all the others.</div><div>When you begin an AutoCAD file you should use an already setted file whith all the necessary utilities such as :</div><div>Paper size for printing, tittle block, layers, DIMENSION STYLE(S) and all the "little" usefull blocks.</div><div>Please tell us if this helped or not.</div><div>Do you have some AutoCAD technical documentation(s) other than the "on line help" F1 ?</div><div>It's possible on the internet a lot of tutorials, do a search with : AutoCAD tutorials.<br><div><br></div></div>]]>
   <pubDate>Thu, 26 Mar 2020 08:30:19 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13398&amp;PID=37487&amp;title=new-to-cad-need-help#37487</guid>
   <title><![CDATA[New to CAD need help : Using my student license, I&amp;#039;ve...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13398&amp;PID=37486&amp;title=new-to-cad-need-help#37486</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=840519">stefanerickson</a><br /><strong>Subject:</strong> 13398<br /><strong>Posted:</strong> 25.Mar.2020 at 18:50<br /><br />Using my student license, I've been working on a bit of a passion project making my own custom subwoofer enclosure. I have it created in AutoCAD2020, but now I want the measurements of each individual piece so I can cut them out. There is 34 pieces and it would be too time consuming to just use the measuring tool. Is there a way to be given the dimensions of each individual piece?]]>
   <pubDate>Wed, 25 Mar 2020 18:50:52 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13398&amp;PID=37486&amp;title=new-to-cad-need-help#37486</guid>
