  <title>CAD Forum discussion (EN) : DWG Points to Contour Lines</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : Civil 3D, Map, InfraWorks : DWG Points to Contour Lines]]></description>
  <pubDate>Thu, 27 Aug 2026 23:43:21 +0000</pubDate>
  <lastBuildDate>Wed, 23 Sep 2020 09:22:57 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=13496</WebWizForums:feedURL>
   <title><![CDATA[DWG Points to Contour Lines : Yes, it is possible.First You...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13496&amp;PID=37734&amp;title=dwg-points-to-contour-lines#37734</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=640807">niyaskumble</a><br /><strong>Subject:</strong> 13496<br /><strong>Posted:</strong> 23.Sep.2020 at 09:22<br /><br />Yes, it is possible.<div><br></div><div>First You open this DWG points in CIVIL 3D.</div><div><br></div><div>Then select surfaces in tool space - right click&nbsp; - creat surface</div><div><br></div><div>Surfaces - surface(name) - definition - drawing object - Right click - Add</div><div><br></div><div>Then Select these points.</div><div><br></div><div>Surface will be created</div><div><br></div><div><br></div>]]>
   <pubDate>Wed, 23 Sep 2020 09:22:57 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13496&amp;PID=37734&amp;title=dwg-points-to-contour-lines#37734</guid>
   <title><![CDATA[DWG Points to Contour Lines : Hello rob-held, I don&amp;#039;t know...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13496&amp;PID=37723&amp;title=dwg-points-to-contour-lines#37723</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=175428">philippe JOSEPH</a><br /><strong>Subject:</strong> 13496<br /><strong>Posted:</strong> 14.Sep.2020 at 21:20<br /><br />Hello rob-held, I don't know about Civil 3d but maybe this is for you, read all the Tip and not only the tittle :<div><t></t><table cellspacing="1" style="color: rgb0, 0, 0; font-family: Tahoma, Arial, sans-serif; font-size: 12px; : rgb242, 242, 242; border-left: 1px solid rgb102, 102, 153;"><t><tr><td ="msgqtxtsa"="" nowrap="" style="font-size: 8pt; border-color: rgb170, 204, 238; color: rgb51, 51, 51;">Tip 11511:</td><td nowrap="" style="font-size: 9pt; border-color: rgb170, 204, 238;"><img src="https://www.cadforum.cz/cadforum_en/img/cf1.gif" height="12" width="19" border="0" alt="score 305" title="score 305" /><img src="https://www.cadforum.cz/cadforum_en/img/cf0.gif" height="12" width="4" border="0" /></td><td ="msgqtxtsa"="" style="font-size: 8pt; border-color: rgb170, 204, 238; color: rgb51, 51, 51;"><a href="https://www.cadforum.cz/cadforum_en/assigning-elevations-to-2d-cotours-isolines-tip11511" rel="nofollow">Assigning elevations to 2D contours (isolines).</a></td></tr></t></table>P.S. Maybe the tip won't solve all your problems.</div><span style="font-size:10px"><br /><br />Edited by philippe JOSEPH - 14.Sep.2020 at 21:30</span>]]>
   <pubDate>Mon, 14 Sep 2020 21:20:56 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13496&amp;PID=37723&amp;title=dwg-points-to-contour-lines#37723</guid>
   <title><![CDATA[DWG Points to Contour Lines : Hello!I am loosing my mind right...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13496&amp;PID=37722&amp;title=dwg-points-to-contour-lines#37722</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=855781">rob-held</a><br /><strong>Subject:</strong> 13496<br /><strong>Posted:</strong> 14.Sep.2020 at 02:20<br /><br />Hello!<div>I am loosing my mind right now. I am trying to convert the attached DWG points to Contour lines.&nbsp;</div><div>Is there anyone who would be able to help me with this?</div><div>Thank you so much!</div><div>Rob</div><div><br></div><div><a href="uploads/855781/Konturpunkte.dwg" target="_blank" rel="nofollow">uploads/855781/Konturpunkte.dwg</a></div>]]>
   <pubDate>Mon, 14 Sep 2020 02:20:29 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13496&amp;PID=37722&amp;title=dwg-points-to-contour-lines#37722</guid>
