  <title>CAD Forum discussion (EN) : Editing 3D solid difficulties</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Editing 3D solid difficulties]]></description>
  <pubDate>Sat, 05 Sep 2026 05:36:05 +0000</pubDate>
  <lastBuildDate>Thu, 14 Jan 2021 19:43:58 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=13544</WebWizForums:feedURL>
   <title><![CDATA[Editing 3D solid difficulties : Denken, you can&amp;#039;t easily...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13544&amp;PID=37846&amp;title=editing-3d-solid-difficulties#37846</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=175428">philippe JOSEPH</a><br /><strong>Subject:</strong> 13544<br /><strong>Posted:</strong> 14.Jan.2021 at 19:43<br /><br />Denken, you can't easily "edit" this object like you could do with Solidworks or an other software with parameters ( maybe Inventor is working like this )&nbsp;but you can modify it by filling the two holes and then recreating thoses holes smaller.<div>You can easily get them bigger by creating some solids to be SUBRACT.</div><div>If you want to acquire 3D CAD skills you will have get a trainning course, find a friend / colleague or dive into some documentation on your own like I did years before, it's possible by simply looking in the documentations at the existing AutoCAD commands.</div><div>In the previously related AutoCAD file of mine ( 3D SOLIDS 01.dwg ) I have listed the main way to do solids creation, modification and some tips about the viewcube, UCS and the use of the UCS for placing dimensions, there is a lot to learn.</div><div>The good thing is to find the official AutoCAD documentation like it was years before as a PDF file loaded on your "C" disk with a name like :&nbsp;AutoCAD_2012_command-ref_enu_v2&#091;1&#093;.pdf but now it's all in the F1 button and it's difficult to work at the same time on your AutoCAD session and with the F1 help.</div><div>You also have many sites with tutorials.........</div><span style="font-size:10px"><br /><br />Edited by philippe JOSEPH - 14.Jan.2021 at 19:45</span>]]>
   <pubDate>Thu, 14 Jan 2021 19:43:58 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13544&amp;PID=37846&amp;title=editing-3d-solid-difficulties#37846</guid>
   <title><![CDATA[Editing 3D solid difficulties :   philippe JOSEPH wrote:Hello...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13544&amp;PID=37845&amp;title=editing-3d-solid-difficulties#37845</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=866646">Dedken</a><br /><strong>Subject:</strong> 13544<br /><strong>Posted:</strong> 14.Jan.2021 at 18:35<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Originally posted by philippe JOSEPH" alt="Originally posted by philippe JOSEPH" style="vertical-align: text-bottom;" /> <strong>philippe JOSEPH wrote:</strong><br /><br />Hello Dedken, yes the instructions are made to make the object from scratch <u>OR</u> by modifying the object ( see the last three steps.<div>If it's too difficult as 3D AutoCAD is not easily modified or whith parameters we ( I ) could do the solid if you give all the dimensions defined in the very first step that I think are enough to define the part.</div><div>You said that you work in 3D with coordinate systems and views and that's very good; do you want to "learn" 3D AutoCAD or modifying this object is enough ?</div><div>Maybe my AutoCAD study is too shortly explained.</div></td></tr></table><div><br></div><div>I will have a go at drawing the object from scratch and then extruding the regions as you suggest, and we'll see how I get on with it. At the moment I just want to edit this object but long term I do want to acquire 3D CAD skills as I want to be able to create objects myself to 3D print.</div><div><br></div><div>Cheers, Ken.</div>]]>
   <pubDate>Thu, 14 Jan 2021 18:35:52 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13544&amp;PID=37845&amp;title=editing-3d-solid-difficulties#37845</guid>
   <title><![CDATA[Editing 3D solid difficulties : Eventually see my AutoCAD file...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13544&amp;PID=37844&amp;title=editing-3d-solid-difficulties#37844</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=175428">philippe JOSEPH</a><br /><strong>Subject:</strong> 13544<br /><strong>Posted:</strong> 14.Jan.2021 at 16:53<br /><br />Eventually see my AutoCAD file : 3D SOLIDS 01.dwg in the CAD/BIM Blocks library here in the site.<span style="font-size:10px"><br /><br />Edited by philippe JOSEPH - 14.Jan.2021 at 16:54</span>]]>
   <pubDate>Thu, 14 Jan 2021 16:53:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13544&amp;PID=37844&amp;title=editing-3d-solid-difficulties#37844</guid>
   <title><![CDATA[Editing 3D solid difficulties : Hello Dedken, yes the instructions...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13544&amp;PID=37843&amp;title=editing-3d-solid-difficulties#37843</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=175428">philippe JOSEPH</a><br /><strong>Subject:</strong> 13544<br /><strong>Posted:</strong> 14.Jan.2021 at 16:46<br /><br />Hello Dedken, yes the instructions are made to make the object from scratch <u>OR</u> by modifying the object ( see the last three steps.<div>If it's too difficult as 3D AutoCAD is not easily modified or whith parameters we ( I ) could do the solid if you give all the dimensions defined in the very first step that I think are enough to define the part.</div><div>You said that you work in 3D with coordinate systems and views and that's very good; do you want to "learn" 3D AutoCAD or modifying this object is enough ?</div><div>Maybe my AutoCAD study is too shortly explained.</div><span style="font-size:10px"><br /><br />Edited by philippe JOSEPH - 14.Jan.2021 at 16:47</span>]]>
   <pubDate>Thu, 14 Jan 2021 16:46:15 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13544&amp;PID=37843&amp;title=editing-3d-solid-difficulties#37843</guid>
   <title><![CDATA[Editing 3D solid difficulties : Hi Philippe,The instructions show...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13544&amp;PID=37842&amp;title=editing-3d-solid-difficulties#37842</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=866646">Dedken</a><br /><strong>Subject:</strong> 13544<br /><strong>Posted:</strong> 14.Jan.2021 at 13:37<br /><br />Hi Philippe,<div><br></div><div>The instructions show made (thankyou for this btw), if I read them correctly they seem to be for making the object from scratch again? Is that what you intended?&nbsp;</div><div><br></div><div>CHeers.</div>]]>
   <pubDate>Thu, 14 Jan 2021 13:37:25 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13544&amp;PID=37842&amp;title=editing-3d-solid-difficulties#37842</guid>
   <title><![CDATA[Editing 3D solid difficulties : Thanks. I will look at this maybe...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13544&amp;PID=37840&amp;title=editing-3d-solid-difficulties#37840</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=866646">Dedken</a><br /><strong>Subject:</strong> 13544<br /><strong>Posted:</strong> 13.Jan.2021 at 11:33<br /><br />Thanks. I will look at this maybe tonight if I have the time]]>
   <pubDate>Wed, 13 Jan 2021 11:33:28 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13544&amp;PID=37840&amp;title=editing-3d-solid-difficulties#37840</guid>
   <title><![CDATA[Editing 3D solid difficulties : Hello again Dedken, I have placed...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13544&amp;PID=37839&amp;title=editing-3d-solid-difficulties#37839</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=175428">philippe JOSEPH</a><br /><strong>Subject:</strong> 13544<br /><strong>Posted:</strong> 13.Jan.2021 at 11:01<br /><br />Hello again Dedken, I have placed in the CAD/BIM Blocks library here in the site the AutoCAD file :<div>EDITION SOLID 3D;dwg with all the steps for the entire solid construction or the modification of the existing one ( see the last three steps ).</div><div>For a good 3D work with AutoCAD ( for me ) you should know all about UCS with all the options even the one that are not written in the command options like UCS by 3 points and all about the 3D point of views + the command PLAN.</div><div>In my work the dimensions placed in the very first step will define entirely the solid geometry; give us yours eventually.</div><div>Please tell us if this helped or not.</div><div>I will be back within 1 hour.</div><span style="font-size:10px"><br /><br />Edited by philippe JOSEPH - 13.Jan.2021 at 11:04</span>]]>
   <pubDate>Wed, 13 Jan 2021 11:01:23 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13544&amp;PID=37839&amp;title=editing-3d-solid-difficulties#37839</guid>
   <title><![CDATA[Editing 3D solid difficulties : Hi, thanks for the reply.I&amp;#039;ve...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13544&amp;PID=37838&amp;title=editing-3d-solid-difficulties#37838</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=866646">Dedken</a><br /><strong>Subject:</strong> 13544<br /><strong>Posted:</strong> 13.Jan.2021 at 09:55<br /><br />Hi, thanks for the reply.<div><br></div><div>I've been using ACAD for 14 years, so I have quite a lot of experience in 2D anyway! I do work in 3D, just not with solids - I work a lot with pointclouds so I am used to switching between coordinates systems and views. I have access to versions from 2017 to present.</div>]]>
   <pubDate>Wed, 13 Jan 2021 09:55:14 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13544&amp;PID=37838&amp;title=editing-3d-solid-difficulties#37838</guid>
   <title><![CDATA[Editing 3D solid difficulties : Hello Denken, I think that you...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13544&amp;PID=37837&amp;title=editing-3d-solid-difficulties#37837</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=175428">philippe JOSEPH</a><br /><strong>Subject:</strong> 13544<br /><strong>Posted:</strong> 13.Jan.2021 at 08:26<br /><br />Hello Denken, I think that you will have to create the solid that you want to add to your model but you can easily rely on the existing solid to do it.<div>In fact 3D AutoCAD is not easily modifing or with parameters.</div><div>I would personally do some regions directly on the existing edges then EXTRUDE and/or REVOLUTION them and UNION them to the existing solid.</div><div>Please tell us about your knoledge of AutoCAD 2D and/or 3D on what AutoDAD year / version.</div><div>I will try to make an "hand sketch3 of what is to be done.&nbsp;</div>]]>
   <pubDate>Wed, 13 Jan 2021 08:26:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13544&amp;PID=37837&amp;title=editing-3d-solid-difficulties#37837</guid>
   <title><![CDATA[Editing 3D solid difficulties : Hello,I&amp;#039;m not new to ACAD...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13544&amp;PID=37836&amp;title=editing-3d-solid-difficulties#37836</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=866646">Dedken</a><br /><strong>Subject:</strong> 13544<br /><strong>Posted:</strong> 13.Jan.2021 at 00:33<br /><br />Hello,&nbsp;<div><br></div><div>I'm not new to ACAD but I am new to 3d modelling. I downloaded an item from thingyverse to 3D print but I need to modify it slightly as some of the dimensions could be tighter. So I converted STL to DXF and then converted all the 3D faces to solid via 'convert to faceted surface' and 'sculpt' commands. I now have an entire 3D solid model which I want to edit but am now stuck as nothing I have tried seems to work. A picture of the item is attached (in top down view) with arrows indicating where I want to modify the dimensions. Basically I want to offset the inside edges by a couple of mm. Can anyone help?</div><div><br></div><div>Many thanks in advance!</div><div><img src="uploads/866646/hose_holster_.png" height="542" width="1040" border="0" /></div>]]>
   <pubDate>Wed, 13 Jan 2021 00:33:17 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13544&amp;PID=37836&amp;title=editing-3d-solid-difficulties#37836</guid>
