  <title>CAD Forum discussion (EN) : Making offsets for postprocessing</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : CAD - general : Making offsets for postprocessing]]></description>
  <pubDate>Mon, 28 Sep 2026 14:11:51 +0000</pubDate>
  <lastBuildDate>Sun, 07 Feb 2021 08:43:25 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=13555</WebWizForums:feedURL>
   <title><![CDATA[Making offsets for postprocessing : Hello luki201098, eventually(...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13555&amp;PID=37869&amp;title=making-offsets-for-postprocessing#37869</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=175428">philippe JOSEPH</a><br /><strong>Subject:</strong> 13555<br /><strong>Posted:</strong> 07.Feb.2021 at 08:43<br /><br />Hello luki201098, eventually&nbsp;( if you have AutoCAD )&nbsp;explore the AutoCAD commands listed in those 2 CAD tips :<div>Number 12064 :&nbsp;3D offset of a surface</div><div>Number 11252 :&nbsp;Applying STRETCH to 3D objects in AutoCAD</div><div>The better would be to re work the solid on its original format file and with the same software if it's with parameters but can you have access to it ?</div><div>Do you want to make a local thickening or local and on what type of solids ?</div><div>Let us know better your type of 3D work.</div><span style="font-size:10px"><br /><br />Edited by philippe JOSEPH - 07.Feb.2021 at 08:47</span>]]>
   <pubDate>Sun, 07 Feb 2021 08:43:25 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13555&amp;PID=37869&amp;title=making-offsets-for-postprocessing#37869</guid>
   <title><![CDATA[Making offsets for postprocessing : Hi,I need to make offsets on parts...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13555&amp;PID=37867&amp;title=making-offsets-for-postprocessing#37867</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=869293">luki201098</a><br /><strong>Subject:</strong> 13555<br /><strong>Posted:</strong> 05.Feb.2021 at 15:57<br /><br /><font size="3">Hi,</font><div><font size="3">I need to make offsets on parts to have enough material that then needs to be milled for the right surface finish. I am trying to find the best solution to do that. I have tried many softwares, NX, Inventor, PowerShape, Fusion360. Options like offset surface/face, don't function very well in small regions, where offset planes intersect eachother. The same happens when offsetting a triangle mesh, fixing those problems after takes a lot of time. Is there a better method or software that does that faster? What other options I have for making such offsets? Thank you in advance :)</font></div>]]>
   <pubDate>Fri, 05 Feb 2021 15:57:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13555&amp;PID=37867&amp;title=making-offsets-for-postprocessing#37867</guid>
