  <title>CAD Forum discussion (EN) : tracing an image</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : tracing an image]]></description>
  <pubDate>Wed, 21 Oct 2026 21:07:35 +0000</pubDate>
  <lastBuildDate>Tue, 20 Apr 2021 20:49:14 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=13583</WebWizForums:feedURL>
   <title><![CDATA[tracing an image : Scan the image and insert it....]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13583&amp;PID=37929&amp;title=tracing-an-image#37929</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=4338">malaycobra</a><br /><strong>Subject:</strong> 13583<br /><strong>Posted:</strong> 20.Apr.2021 at 20:49<br /><br />Scan the image and insert it. Then trace over it. If you have the dimensions of the original then you can measure your tracing then scale it by reference.<div><br></div><div>Select Scale<br>Select objects</div><div>Select a base point</div><div>Type R</div><div>Enter a dimension from your trace</div><div>hit enter</div><div>then type the measurement you want it to be</div><div>You should now have your trace at the correct size. If it didn't perfectly scale, run the steps again and it'll be perfect.</div>]]>
   <pubDate>Tue, 20 Apr 2021 20:49:14 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13583&amp;PID=37929&amp;title=tracing-an-image#37929</guid>
   <title><![CDATA[tracing an image : One way to &amp;#034;trace&amp;#034; an...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13583&amp;PID=37921&amp;title=tracing-an-image#37921</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 13583<br /><strong>Posted:</strong> 17.Apr.2021 at 12:51<br /><br />One way to "trace" an image would be to use a digitizer and puck.&nbsp; But first one must calibrate the screen pointing area before proceeding.&nbsp; Another option would be to take a picture of the silhouette and using the command AttachImage insert the image into your drawing then trace over it after which you can rescale the object to match the original.&nbsp;&nbsp;]]>
   <pubDate>Sat, 17 Apr 2021 12:51:02 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13583&amp;PID=37921&amp;title=tracing-an-image#37921</guid>
   <title><![CDATA[tracing an image : I taped a silhouette to the screen...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13583&amp;PID=37920&amp;title=tracing-an-image#37920</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=809565">Tom Tvn</a><br /><strong>Subject:</strong> 13583<br /><strong>Posted:</strong> 17.Apr.2021 at 00:49<br /><br /><font size="3">I taped a silhouette to the screen and using the "line" command traced the silhouette to a new acad sheet.&nbsp; When I printed &nbsp; the new drawing it was, as I expected to a different scale.&nbsp; I measured the original silhouette and the printout to determine a scale factor.&nbsp; I applied this factor to the drawing and and printed a new drawing.&nbsp; The "Y" axis seemed to scale OK but the "X" was not close.&nbsp; Is it possible to trace an image into acad?&nbsp; Thanks, Tom</font> <br>]]>
   <pubDate>Sat, 17 Apr 2021 00:49:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13583&amp;PID=37920&amp;title=tracing-an-image#37920</guid>
