  <title>CAD Forum discussion (EN) : AutoCAD purge command error</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : AutoCAD purge command error]]></description>
  <pubDate>Sat, 05 Sep 2026 08:17:11 +0000</pubDate>
  <lastBuildDate>Tue, 04 May 2021 14:55:28 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=13595</WebWizForums:feedURL>
   <title><![CDATA[AutoCAD purge command error : ok I will try to repair... thanx...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13595&amp;PID=37954&amp;title=autocad-purge-command-error#37954</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=610705">Zuhaib</a><br /><strong>Subject:</strong> 13595<br /><strong>Posted:</strong> 04.May.2021 at 14:55<br /><br />ok I will try to repair... <br />thanx alot]]>
   <pubDate>Tue, 04 May 2021 14:55:28 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13595&amp;PID=37954&amp;title=autocad-purge-command-error#37954</guid>
   <title><![CDATA[AutoCAD purge command error : You could always try a REPAIR...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13595&amp;PID=37950&amp;title=autocad-purge-command-error#37950</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 13595<br /><strong>Posted:</strong> 04.May.2021 at 12:55<br /><br />You could always try a REPAIR of AutoCAD which is NOT the same as a UNINSTALL/REINSTALL.&nbsp; I'm running AutoCAD 2018 and the Purge command functions properly.]]>
   <pubDate>Tue, 04 May 2021 12:55:02 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13595&amp;PID=37950&amp;title=autocad-purge-command-error#37950</guid>
   <title><![CDATA[AutoCAD purge command error : whenever I use purge command in...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13595&amp;PID=37948&amp;title=autocad-purge-command-error#37948</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=610705">Zuhaib</a><br /><strong>Subject:</strong> 13595<br /><strong>Posted:</strong> 04.May.2021 at 12:46<br /><br />whenever I use purge command in AutoCAD 2021. I found an error (unknown purge command).<br />what is the solution....?<br />plz help]]>
   <pubDate>Tue, 04 May 2021 12:46:16 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13595&amp;PID=37948&amp;title=autocad-purge-command-error#37948</guid>
