  <title>CAD Forum discussion (EN) : SOL2SOLH behaviour</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : ARKANCE (CAD Studio) applications : SOL2SOLH behaviour]]></description>
  <pubDate>Tue, 01 Sep 2026 21:10:57 +0000</pubDate>
  <lastBuildDate>Tue, 25 May 2021 12:55:35 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=13601</WebWizForums:feedURL>
   <title><![CDATA[SOL2SOLH behaviour : Thanks, fixed now - see Download....]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13601&amp;PID=37970&amp;title=sol2solh-behaviour#37970</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 13601<br /><strong>Posted:</strong> 25.May.2021 at 12:55<br /><br />Thanks, fixed now - see Download.]]>
   <pubDate>Tue, 25 May 2021 12:55:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13601&amp;PID=37970&amp;title=sol2solh-behaviour#37970</guid>
   <title><![CDATA[SOL2SOLH behaviour : One more thing.If the solid is...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13601&amp;PID=37969&amp;title=sol2solh-behaviour#37969</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=878569">w64bitcad</a><br /><strong>Subject:</strong> 13601<br /><strong>Posted:</strong> 25.May.2021 at 10:51<br /><br /><div>One more thing.</div><div>If the solid is in Layout the resulted hatch will be created in Model.</div>]]>
   <pubDate>Tue, 25 May 2021 10:51:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13601&amp;PID=37969&amp;title=sol2solh-behaviour#37969</guid>
   <title><![CDATA[SOL2SOLH behaviour : Thanks for sending a sample drawing....]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13601&amp;PID=37960&amp;title=sol2solh-behaviour#37960</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 13601<br /><strong>Posted:</strong> 18.May.2021 at 09:44<br /><br />Thanks for sending a sample drawing. Those solids had negative extrusion vectors - fixed Sol2SolH to handle these special types of objects (see V1.2 on Download).]]>
   <pubDate>Tue, 18 May 2021 09:44:58 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13601&amp;PID=37960&amp;title=sol2solh-behaviour#37960</guid>
   <title><![CDATA[SOL2SOLH behaviour : I tried SOL2SOLH on several drawings...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13601&amp;PID=37959&amp;title=sol2solh-behaviour#37959</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=878569">w64bitcad</a><br /><strong>Subject:</strong> 13601<br /><strong>Posted:</strong> 18.May.2021 at 09:08<br /><br /><div>I tried SOL2SOLH on several drawings and I found that on some of them the hatches are created away from original solid objects.</div><div>This is a VLX problem or a DWG problem?</div><div>Thank you</div><div><a href="uploads/878569/Drawing1.dwg" target="_blank" rel="nofollow">uploads/878569/Drawing1.dwg</a><br></div><span style="font-size:10px"><br /><br />Edited by w64bitcad - 18.May.2021 at 09:09</span>]]>
   <pubDate>Tue, 18 May 2021 09:08:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13601&amp;PID=37959&amp;title=sol2solh-behaviour#37959</guid>
