  <title>CAD Forum discussion (EN) : Convert Hatch to Solid</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Convert Hatch to Solid]]></description>
  <pubDate>Sat, 05 Sep 2026 08:42:55 +0000</pubDate>
  <lastBuildDate>Tue, 14 Jun 2022 18:12:31 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=13716</WebWizForums:feedURL>
   <title><![CDATA[Convert Hatch to Solid : As mentioned, read about commands...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13716&amp;PID=38266&amp;title=convert-hatch-to-solid#38266</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=353260">Kent Cooper</a><br /><strong>Subject:</strong> 13716<br /><strong>Posted:</strong> 14.Jun.2022 at 18:12<br /><br />As mentioned, read about commands like EXTRUDE, REVOLVE, PRESSPULL, LOFT, SWEEP.<div><br></div><div>If you have a Hatch pattern but do not have its boundary to Extrude &#091;or whatever&#093;, you can select it, right-click, and choose Generate Boundary, which will do so, and you can use those 3D-making commands on the resulting Polyline or Region.</div>]]>
   <pubDate>Tue, 14 Jun 2022 18:12:31 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13716&amp;PID=38266&amp;title=convert-hatch-to-solid#38266</guid>
   <title><![CDATA[Convert Hatch to Solid : You can get a 3D solid from a...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13716&amp;PID=38263&amp;title=convert-hatch-to-solid#38263</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=175428">philippe JOSEPH</a><br /><strong>Subject:</strong> 13716<br /><strong>Posted:</strong> 09.Jun.2022 at 14:15<br /><br />You can get a 3D solid from a closed entity like a REGION that you will EXTRUDE at height or along a path or REVOLVE around an axis or other possibilities.<div>Eventually see my AutoCAD file : 3D SOLIDS 01.dwg that you will find in the CAD/BIM Blocks here in the site.</div><div>It shows the main 3D AutoCAD commands.</div><div>P.S. What do you know about 3D like everything about UCS settings, Point of views, commands, etc... ?</div><div><br></div><span style="font-size:10px"><br /><br />Edited by philippe JOSEPH - 09.Jun.2022 at 14:19</span>]]>
   <pubDate>Thu, 09 Jun 2022 14:15:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13716&amp;PID=38263&amp;title=convert-hatch-to-solid#38263</guid>
   <title><![CDATA[Convert Hatch to Solid : Hello,i would like to know how...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13716&amp;PID=38262&amp;title=convert-hatch-to-solid#38262</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=906741">sasabgd12</a><br /><strong>Subject:</strong> 13716<br /><strong>Posted:</strong> 09.Jun.2022 at 09:17<br /><br />Hello,<div>i would like to know how to convert hatch object to solid object. Or convert closed polyline in solid object with boundaries of that poliline.&nbsp; Does it exist such possibility?</div><div>Thanks in advance</div>]]>
   <pubDate>Thu, 09 Jun 2022 09:17:12 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13716&amp;PID=38262&amp;title=convert-hatch-to-solid#38262</guid>
