  <title>CAD Forum discussion (EN) : ACAD Lt 2023 trial</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : ACAD Lt 2023 trial]]></description>
  <pubDate>Sat, 05 Sep 2026 19:54:55 +0000</pubDate>
  <lastBuildDate>Sun, 18 Sep 2022 08:14:19 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=13750</WebWizForums:feedURL>
   <title><![CDATA[ACAD Lt 2023 trial : Hello rhbelter, what I see on...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13750&amp;PID=38379&amp;title=acad-lt-2023-trial#38379</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=175428">philippe JOSEPH</a><br /><strong>Subject:</strong> 13750<br /><strong>Posted:</strong> 18.Sep.2022 at 08:14<br /><br />Hello rhbelter, what I see on the F2 read out are the 3 last commnds that you tiped :<div>2 canceled aligned dimensions and one layed but no sign of a block upload.</div><div><br></div><div>For the AutoCAD product I'm not abble to do anything and this is terrible when it happens to you.</div><div><br></div><div>A precision for me : when you talk about block insert "from libraries", are you talking of inserting a block already inside the file or from outside the file ?</div><div>If it's from outside, eventually try a copy/paste by opening the other file, even if it's not satisfactory because you will loose the exact WBLOCK file name and also the correct insertion point; or you will have to re-block it inside your file correctly.</div><div><br></div><div>An other point : You are talking about a "trial" version of a "LT" AutoCAD.</div><div>Maybe this is the point and I do prefer an old "plain" AutoCAD than a "Trial LT" that will not last forever anyway.</div><div>If it's "only" for home works ( I don't your needs ) it's better an old plain version.</div><span style="font-size:10px"><br /><br />Edited by philippe JOSEPH - 18.Sep.2022 at 08:27</span>]]>
   <pubDate>Sun, 18 Sep 2022 08:14:19 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13750&amp;PID=38379&amp;title=acad-lt-2023-trial#38379</guid>
   <title><![CDATA[ACAD Lt 2023 trial : Ahoy, All,My problem is with &amp;#039;insert&amp;#039;...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13750&amp;PID=38378&amp;title=acad-lt-2023-trial#38378</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=200041">rhbelter</a><br /><strong>Subject:</strong> 13750<br /><strong>Posted:</strong> 17.Sep.2022 at 19:39<br /><br />Ahoy, All,&nbsp;<div><br></div><div>My problem is with 'insert' blocks from libraries.&nbsp; It was ok when I first installed ACAD LT 2023 trial, but, now, it does not work.&nbsp; I remain convinced that the file is corrupted, but all my attempts to work my way through the Autodesk '&nbsp;bureaurocracy' in order to gain a new download have&nbsp; been unsucessful.&nbsp; Uninstall it, and try&nbsp; for a new installation???&nbsp; Please suggest.</div><div><br></div><div>Thanks&nbsp; &nbsp; &nbsp;/s/&nbsp; &nbsp; &nbsp; Bob&nbsp;&nbsp;</div>]]>
   <pubDate>Sat, 17 Sep 2022 19:39:24 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13750&amp;PID=38378&amp;title=acad-lt-2023-trial#38378</guid>
   <title><![CDATA[ACAD Lt 2023 trial : Ahoy, philippe Joseph, Here, is...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13750&amp;PID=38377&amp;title=acad-lt-2023-trial#38377</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=200041">rhbelter</a><br /><strong>Subject:</strong> 13750<br /><strong>Posted:</strong> 17.Sep.2022 at 19:03<br /><br />Ahoy, philippe Joseph, Here, is the&nbsp;<div>F2 read out:&nbsp;&nbsp;</div><div>&nbsp; :</div><div>Command:</div><div>Command: _dimaligned</div><div>Specify first extension line origin or &lt;select object&gt;: *Cancel*</div><div>Command:</div><div>Command: _dimaligned</div><div>Specify first extension line origin or &lt;select object&gt;: *Cancel*</div><div>Command:</div><div>Command: _dimaligned</div><div>Specify first extension line origin or &lt;select object&gt;:&nbsp; &lt;Osnap on&gt;</div><div>Specify second extension line origin:</div><div>Specify dimension line location or</div><div>&#091;Mtext/Text/Angle&#093;: *Cancel*</div><div>Command:</div><div><br></div><div>It means nothing to me ????</div><div><br></div><div>Thanks&nbsp; &nbsp; &nbsp; /s/&nbsp; &nbsp; &nbsp; Bob</div><div><br></div>]]>
   <pubDate>Sat, 17 Sep 2022 19:03:29 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13750&amp;PID=38377&amp;title=acad-lt-2023-trial#38377</guid>
   <title><![CDATA[ACAD Lt 2023 trial : Hello again rhbelter, what do...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13750&amp;PID=38366&amp;title=acad-lt-2023-trial#38366</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=175428">philippe JOSEPH</a><br /><strong>Subject:</strong> 13750<br /><strong>Posted:</strong> 15.Sep.2022 at 18:09<br /><br />Hello again rhbelter, what do you read on the command line when typing F2 after your block insert attempt ?<div>An access to DDIM will allow you setting properly your dimensions, it's important to set everything correctly to your desires.</div><div>Normally to begin a new file you use an already set file of yours with your lines, dimensions, text styles, paper sizes, tittle blocks, etc...</div><span style="font-size:10px"><br /><br />Edited by philippe JOSEPH - 15.Sep.2022 at 18:20</span>]]>
   <pubDate>Thu, 15 Sep 2022 18:09:24 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13750&amp;PID=38366&amp;title=acad-lt-2023-trial#38366</guid>
   <title><![CDATA[ACAD Lt 2023 trial : Ahoy, philippe JOSEPH,Thank you...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13750&amp;PID=38365&amp;title=acad-lt-2023-trial#38365</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=200041">rhbelter</a><br /><strong>Subject:</strong> 13750<br /><strong>Posted:</strong> 15.Sep.2022 at 17:31<br /><br />Ahoy, philippe JOSEPH,<div>Thank you for your response.</div><div>The&nbsp;<span style=": rgb251, 251, 253; color: rgb54, 69, 90; font-size: small;">DDIM / ... / Primary Units. did solve the decimal place problem, but the&nbsp;</span></div><div><span style=": rgb251, 251, 253;"><font color="#36455a" size="2">insert problem persists.&nbsp; The 'insert' worked when the trial was first received,</font></span></div><div><span style=": rgb251, 251, 253;"><font color="#36455a" size="2">But no longer.&nbsp; The ACAD LT 2023 may have become corrupted, and I don't see</font></span></div><div><span style=": rgb251, 251, 253;"><font color="#36455a" size="2">any way to 'repair' a file in Windows 10.</font></span></div><div><span style=": rgb251, 251, 253;"><font color="#36455a" size="2"><br></font></span></div><div><span style=": rgb251, 251, 253;"><font color="#36455a" size="2">Thanks&nbsp; &nbsp; &nbsp;/s/&nbsp; &nbsp; &nbsp; &nbsp;Bob&nbsp;</font></span></div>]]>
   <pubDate>Thu, 15 Sep 2022 17:31:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13750&amp;PID=38365&amp;title=acad-lt-2023-trial#38365</guid>
   <title><![CDATA[ACAD Lt 2023 trial : Hello rhbelter.Units : You set...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13750&amp;PID=38362&amp;title=acad-lt-2023-trial#38362</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=175428">philippe JOSEPH</a><br /><strong>Subject:</strong> 13750<br /><strong>Posted:</strong> 15.Sep.2022 at 08:16<br /><br />Hello rhbelter.<div><br><div>Units : You set your UNITS and the precision is not set correctly on the informations that you get on the dimensions that you place with DIMLINEAR and DIMANGULAR ?</div><div>You have to set the precisions with DDIM / ... / Primary Units.</div><div>Eventually show us a printscreen of your settings.</div><div><br></div><div>Insert BLOCK : Eventually try the double clic and type F2 to see the eventual error message.</div></div>]]>
   <pubDate>Thu, 15 Sep 2022 08:16:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13750&amp;PID=38362&amp;title=acad-lt-2023-trial#38362</guid>
   <title><![CDATA[ACAD Lt 2023 trial : Old to ACAD, retired, new to ACAD...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13750&amp;PID=38361&amp;title=acad-lt-2023-trial#38361</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=200041">rhbelter</a><br /><strong>Subject:</strong> 13750<br /><strong>Posted:</strong> 14.Sep.2022 at 22:53<br /><br />Old to ACAD, retired, new to ACAD LT 2023 Trial:&nbsp;&nbsp;<div>Problem:&nbsp; Units. When set to decimal -w- 3 decimal place linear and angular, yield is 4 decimal places for linear and no decimals for angular.&nbsp; &nbsp; ??????</div><div><br></div><div>Problem:&nbsp;&nbsp;</div><div>insert block:&nbsp; chose 'blocks from libraries'&nbsp; make a selection and screen shows blocks desired, try to slide it, no work select 'open' and it disappears.&nbsp; &nbsp; &nbsp;?????</div><div><br></div><div>Program bad, or ME???&nbsp; &nbsp; &nbsp; /s/&nbsp; &nbsp; &nbsp;Bob</div><div>&nbsp;</div>]]>
   <pubDate>Wed, 14 Sep 2022 22:53:29 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13750&amp;PID=38361&amp;title=acad-lt-2023-trial#38361</guid>
