  <title>CAD Forum discussion (EN) : swing ange of door</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : CAD - general : swing ange of door]]></description>
  <pubDate>Wed, 08 Jul 2026 12:35:31 +0000</pubDate>
  <lastBuildDate>Tue, 02 Dec 2008 13:41:17 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=1377</WebWizForums:feedURL>
   <title><![CDATA[swing ange of door : It works. Thank you very much....]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1377&amp;PID=3798&amp;title=swing-ange-of-door#3798</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=23298">danielito6</a><br /><strong>Subject:</strong> 1377<br /><strong>Posted:</strong> 02.Dec.2008 at 13:41<br /><br /><P><img src="http://www.cadforum.cz/forum_en/smileys/smiley1.gif" height="17" width="17" border="0" align="absmiddle" alt="Smile" />&nbsp;It works. Thank you very much.</P>]]>
   <pubDate>Tue, 02 Dec 2008 13:41:17 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1377&amp;PID=3798&amp;title=swing-ange-of-door#3798</guid>
   <title><![CDATA[swing ange of door : Ok, here is the solution for you...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1377&amp;PID=3772&amp;title=swing-ange-of-door#3772</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=9961">Ringis</a><br /><strong>Subject:</strong> 1377<br /><strong>Posted:</strong> 28.Nov.2008 at 14:43<br /><br />Ok, here is the solution for you (hopefully)! First, excuse me for bad English! <DIV>&nbsp;</DIV><DIV>Select your door, right click and select "edit door style" then select "Display properties" This is were you can change everything how it should behave in different display configurations.&nbsp; </DIV><DIV>&nbsp;</DIV><DIV>Choose the one which controls the presentation mode (don´t know which one it is&nbsp;in your settings but there´s a couple too choose from)&nbsp;but it does´t matter for this explaining they look almost the same. </DIV><DIV>&nbsp;</DIV><DIV>For example, choose "plan" and then click the button on the right side (if you check the little box "style override" your changes will only control this object, if not every door with this doorstyle will be changed)</DIV><DIV>&nbsp;</DIV><DIV>Now you click the menu "other" and at the bottom there is a little box "override opening percent" And there is your box! </DIV><DIV>&nbsp;</DIV><DIV>Hopefully this will solve your issue!</DIV><DIV>&nbsp;</DIV><DIV>//Tobias</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV>]]>
   <pubDate>Fri, 28 Nov 2008 14:43:23 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1377&amp;PID=3772&amp;title=swing-ange-of-door#3772</guid>
   <title><![CDATA[swing ange of door : Hi I use ADT 2008  when i am...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1377&amp;PID=3748&amp;title=swing-ange-of-door#3748</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=23298">danielito6</a><br /><strong>Subject:</strong> 1377<br /><strong>Posted:</strong> 27.Nov.2008 at 16:59<br /><br />Hi I use ADT 2008 <DIV>when i am in normal&nbsp; display cofiguration my door is close. My swing angle is 0. But if I change display configuration from normal to presentation my dor is open . If i go to properties I can see that the swing angle is&nbsp; still 0 but my door is open!!</DIV><DIV>anyone ho can help me<img src="http://www.cadforum.cz/forum_en/smileys/smiley19.gif" height="17" width="17" border="0" align="absmiddle" alt="Cry" /></DIV>]]>
   <pubDate>Thu, 27 Nov 2008 16:59:01 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1377&amp;PID=3748&amp;title=swing-ange-of-door#3748</guid>
