  <title>CAD Forum discussion (EN) : AutoCAD to .pdf - missing information</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : AutoCAD to .pdf - missing information]]></description>
  <pubDate>Sat, 05 Sep 2026 18:52:18 +0000</pubDate>
  <lastBuildDate>Mon, 01 Dec 2008 17:03:10 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=1381</WebWizForums:feedURL>
   <title><![CDATA[AutoCAD to .pdf - missing information :    GaryMichael wrote:I am using...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1381&amp;PID=3795&amp;title=autocad-to-pdf-missing-information#3795</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=22753">rossassociates</a><br /><strong>Subject:</strong> 1381<br /><strong>Posted:</strong> 01.Dec.2008 at 17:03<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Originally posted by GaryMichael" alt="Originally posted by GaryMichael" style="vertical-align: text-bottom;" /> <strong>GaryMichael wrote:</strong><br /><br />I am using DWG to PDF Converter by Autodwg.com, it converts my dwg files to pdf files easily and quickly, free trail of DWG to PDF converter software is available for download form here: <a href="http://www.autodwg.com/PDF/" target="_blank"><font color="#810081">http://www.autodwg.com/PDF/</font></a><br>I did download and run this application for almost one year, nothing lost.<br></td></tr></table><br><br>Why?&nbsp; Use cutePDF instead, it works (as a printer driver) and doesn't cover the output in watermarks or identify it as having been printed with cutePDF..<br>]]>
   <pubDate>Mon, 01 Dec 2008 17:03:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1381&amp;PID=3795&amp;title=autocad-to-pdf-missing-information#3795</guid>
   <title><![CDATA[AutoCAD to .pdf - missing information : Please avoid using any external...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1381&amp;PID=3783&amp;title=autocad-to-pdf-missing-information#3783</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 1381<br /><strong>Posted:</strong> 29.Nov.2008 at 13:10<br /><br />Please avoid using any external <EM><strong>DWG-to-something</strong></EM> convertes. Only AutoCAD can understand all types of entities and information inside DWG files.<DIV>&nbsp;</DIV><DIV><DIV></DIV>When you use the native AutoCAD export to PDF or a virtual PDF printer to print your drawings from AutoCAD, no information will be lost (you can also use it to batch convert DWGs to PDF).&nbsp;Any external tool will loose some information as it cannot fully <EM>understand</EM> the DWG file format.</DIV>]]>
   <pubDate>Sat, 29 Nov 2008 13:10:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1381&amp;PID=3783&amp;title=autocad-to-pdf-missing-information#3783</guid>
   <title><![CDATA[AutoCAD to .pdf - missing information : I am using DWG to PDF Converter...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1381&amp;PID=3780&amp;title=autocad-to-pdf-missing-information#3780</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=27006">GaryMichael</a><br /><strong>Subject:</strong> 1381<br /><strong>Posted:</strong> 29.Nov.2008 at 08:52<br /><br />I am using DWG to PDF Converter by Autodwg.com, it converts my dwg files to pdf files easily and quickly, free trail of DWG to PDF converter software is available for download form here: <a href="http://www.autodwg.com/PDF/" target="_blank"><FONT color=#810081>http://www.autodwg.com/PDF/</FONT></A><BR>I did download and run this application for almost one year, nothing lost.<BR>]]>
   <pubDate>Sat, 29 Nov 2008 08:52:00 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1381&amp;PID=3780&amp;title=autocad-to-pdf-missing-information#3780</guid>
   <title><![CDATA[AutoCAD to .pdf - missing information : we had similar issue in our office....]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1381&amp;PID=3773&amp;title=autocad-to-pdf-missing-information#3773</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=23910">Kajito</a><br /><strong>Subject:</strong> 1381<br /><strong>Posted:</strong> 28.Nov.2008 at 14:44<br /><br />we had similar issue in our office. But the problem was with version of acrobat reader used. We are using for pdf creation acrobat 7. When we opened some drawings in reader 6 or 7, some objects were missing or we had some straight lines thro the drawing. When we used reader 8 or 9, the drawing was as expected. <br />So my advise is to try to open it in reader 9 if it is not just reader failure.]]>
   <pubDate>Fri, 28 Nov 2008 14:44:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1381&amp;PID=3773&amp;title=autocad-to-pdf-missing-information#3773</guid>
   <title><![CDATA[AutoCAD to .pdf - missing information : What information is missing? (!)...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1381&amp;PID=3767&amp;title=autocad-to-pdf-missing-information#3767</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=22753">rossassociates</a><br /><strong>Subject:</strong> 1381<br /><strong>Posted:</strong> 28.Nov.2008 at 13:36<br /><br />What information is missing? (!)&nbsp; Is this on a layer that is set not to plot?<br><br>If you attempt to plot the drawing and check a Preview, is the information there, or is it also missing?&nbsp; If it's missing on the Preview, then it's more than likely that it's on a layer that isn't set to be plotted.&nbsp; Check what layer the offending item or items are on and then check using the Layer Manager.<br><br>HTH<br><br>]]>
   <pubDate>Fri, 28 Nov 2008 13:36:33 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1381&amp;PID=3767&amp;title=autocad-to-pdf-missing-information#3767</guid>
   <title><![CDATA[AutoCAD to .pdf - missing information :   BarbaraKathari wrote:We are...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1381&amp;PID=3757&amp;title=autocad-to-pdf-missing-information#3757</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=2361">Arben.Allaraj</a><br /><strong>Subject:</strong> 1381<br /><strong>Posted:</strong> 28.Nov.2008 at 09:48<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Originally posted by BarbaraKathari" alt="Originally posted by BarbaraKathari" style="vertical-align: text-bottom;" /> <strong>BarbaraKathari wrote:</strong><br /><br />We are a consulting engineering firm using AutoCAD 2008, we have recently noticed that on a number of .pdf files that some of our information is missing. Could this be because the .dwg doesn't fully regenerate before plotting? If this is the case, how do we stop it happening? If not, are there any other ideas on how to rectify this problem?</td></tr></table> <DIV>&nbsp;</DIV><DIV>&nbsp;</DIV><DIV>Maybe you should check&nbsp;some &nbsp;features of them&nbsp;ex. layers , xref-s,size ect.</DIV>]]>
   <pubDate>Fri, 28 Nov 2008 09:48:25 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1381&amp;PID=3757&amp;title=autocad-to-pdf-missing-information#3757</guid>
   <title><![CDATA[AutoCAD to .pdf - missing information : We are a consulting engineering...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1381&amp;PID=3753&amp;title=autocad-to-pdf-missing-information#3753</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=27956">BarbaraKathari</a><br /><strong>Subject:</strong> 1381<br /><strong>Posted:</strong> 28.Nov.2008 at 07:43<br /><br />We are a consulting engineering firm using AutoCAD 2008, we haverecently noticed that on a number of .pdf files that some of ourinformation is missing. Could this be because the .dwg doesn't fullyregenerate before plotting? If this is the case, how do we stop ithappening? If not, are there any other ideas on how to rectify thisproblem?]]>
   <pubDate>Fri, 28 Nov 2008 07:43:42 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1381&amp;PID=3753&amp;title=autocad-to-pdf-missing-information#3753</guid>
