  <title>CAD Forum discussion (EN) : error message problem</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : error message problem]]></description>
  <pubDate>Sat, 05 Sep 2026 14:54:26 +0000</pubDate>
  <lastBuildDate>Wed, 03 Dec 2008 16:28:48 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=1389</WebWizForums:feedURL>
   <title><![CDATA[error message problem : thanks guys,much appreciated with...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1389&amp;PID=3821&amp;title=error-message-problem#3821</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=27228">iwaddell</a><br /><strong>Subject:</strong> 1389<br /><strong>Posted:</strong> 03.Dec.2008 at 16:28<br /><br />thanks guys,<br>much appreciated with the information about the error message. problem solved.<br>cheers<br>ian<br>]]>
   <pubDate>Wed, 03 Dec 2008 16:28:48 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1389&amp;PID=3821&amp;title=error-message-problem#3821</guid>
   <title><![CDATA[error message problem :    iwaddell wrote:hello all,im...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1389&amp;PID=3794&amp;title=error-message-problem#3794</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=2361">Arben.Allaraj</a><br /><strong>Subject:</strong> 1389<br /><strong>Posted:</strong> 01.Dec.2008 at 15:17<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Originally posted by iwaddell" alt="Originally posted by iwaddell" style="vertical-align: text-bottom;" /> <strong>iwaddell wrote:</strong><br /><br />hello all,<br>im new to this forum but have been using cad since release 12. but have only now been getting this error message <br><br>ARX_ERROR: eNotThatKindOfClass<br><br>but only in a couple of files. anyone came across this before? only way i have found to get rid of it is to create a new files and then copy and paste everything into the new file. but when you have 15 paper space tabs it takes forever and then having to reset all the viewports.<br><br>i use AutoCAD2006 just now but also have AutoCAD2009 installed. but need to upgrade memory to run it properly, while i get funds for a new machine.<br><br>any help is appreciated.<br>Ian<br></td></tr></table><br><br>Check this URL:http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&amp;id=7047371&amp;linkID=9240618<br>]]>
   <pubDate>Mon, 01 Dec 2008 15:17:55 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1389&amp;PID=3794&amp;title=error-message-problem#3794</guid>
   <title><![CDATA[error message problem :   It becomes when there is new...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1389&amp;PID=3793&amp;title=error-message-problem#3793</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=20994">Kackac</a><br /><strong>Subject:</strong> 1389<br /><strong>Posted:</strong> 01.Dec.2008 at 14:37<br /><br />It becomes when there is new objects in the drawing (eg. from newer version of cad). Install Object Enabler (you'll find it here in Downloads).<br>More information in tip <a href="http://www.cadforum.cz/cadforum_en/qaID.asp?tip=4922" target="_blank">#4922</a> or eg. <a href="http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=7191652&linkID=9240857" target="_blank">here</a>... (doesn't matter that it is for MAP, I thing, it's similar)<br><span style="font-size:10px"><br /><br />Edited by Kackac - 01.Dec.2008 at 14:42</span>]]>
   <pubDate>Mon, 01 Dec 2008 14:37:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1389&amp;PID=3793&amp;title=error-message-problem#3793</guid>
   <title><![CDATA[error message problem : hello all,im new to this forum...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1389&amp;PID=3792&amp;title=error-message-problem#3792</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=27228">iwaddell</a><br /><strong>Subject:</strong> 1389<br /><strong>Posted:</strong> 01.Dec.2008 at 13:15<br /><br />hello all,<br>im new to this forum but have been using cad since release 12. but have only now been getting this error message <br><br>ARX_ERROR: eNotThatKindOfClass<br><br>but only in a couple of files. anyone came across this before? only way i have found to get rid of it is to create a new files and then copy and paste everything into the new file. but when you have 15 paper space tabs it takes forever and then having to reset all the viewports.<br><br>i use AutoCAD2006 just now but also have AutoCAD2009 installed. but need to upgrade memory to run it properly, while i get funds for a new machine.<br><br>any help is appreciated.<br>Ian<br>]]>
   <pubDate>Mon, 01 Dec 2008 13:15:26 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1389&amp;PID=3792&amp;title=error-message-problem#3792</guid>
