  <title>CAD Forum discussion (EN) : copy command</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : copy command]]></description>
  <pubDate>Tue, 27 Oct 2026 04:07:34 +0000</pubDate>
  <lastBuildDate>Fri, 05 Dec 2008 07:24:27 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=1401</WebWizForums:feedURL>
   <title><![CDATA[copy command : But ARRAY can&amp;#039;t align objects...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1401&amp;PID=3849&amp;title=copy-command#3849</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=20994">Kackac</a><br /><strong>Subject:</strong> 1401<br /><strong>Posted:</strong> 05.Dec.2008 at 07:24<br /><br />But &#091;CMD&#093;ARRAY&#091;/CMD&#093; can't align objects to splines and curves in general, but only makes rectangular matrix or circle.<br>]]>
   <pubDate>Fri, 05 Dec 2008 07:24:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1401&amp;PID=3849&amp;title=copy-command#3849</guid>
   <title><![CDATA[copy command : Try Array rather than copy. When...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1401&amp;PID=3844&amp;title=copy-command#3844</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=18399">Ron C</a><br /><strong>Subject:</strong> 1401<br /><strong>Posted:</strong> 04.Dec.2008 at 19:53<br /><br />Try Array rather than copy.&nbsp; When asked for distance, pick the points.]]>
   <pubDate>Thu, 04 Dec 2008 19:53:33 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1401&amp;PID=3844&amp;title=copy-command#3844</guid>
   <title><![CDATA[copy command : thank you very much for the advise... ...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1401&amp;PID=3836&amp;title=copy-command#3836</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=28626">jmam</a><br /><strong>Subject:</strong> 1401<br /><strong>Posted:</strong> 04.Dec.2008 at 15:48<br /><br />thank you very much for the advise...]]>
   <pubDate>Thu, 04 Dec 2008 15:48:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1401&amp;PID=3836&amp;title=copy-command#3836</guid>
   <title><![CDATA[copy command :  CommandMEASURE (inserts points...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1401&amp;PID=3819&amp;title=copy-command#3819</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=20994">Kackac</a><br /><strong>Subject:</strong> 1401<br /><strong>Posted:</strong> 03.Dec.2008 at 16:07<br /><br />Command&nbsp;&#091;CMD&#093;MEASURE&#091;/CMD&#093; (inserts points or block by exact distance) or &#091;CMD&#093;DIVIDE&#091;/CMD&#093; (divides a curve inserting poitns or blocks to a number of segments).<span style="font-size:10px"><br /><br />Edited by Kackac - 03.Dec.2008 at 16:16</span>]]>
   <pubDate>Wed, 03 Dec 2008 16:07:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1401&amp;PID=3819&amp;title=copy-command#3819</guid>
   <title><![CDATA[copy command : how to make multiple copies of...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1401&amp;PID=3816&amp;title=copy-command#3816</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=28626">jmam</a><br /><strong>Subject:</strong> 1401<br /><strong>Posted:</strong> 03.Dec.2008 at 11:46<br /><br />how to make multiple copies of an object that will align automatically to an spline with equal spacing?... ex. A circle will be multiple copied with equal spacing but aligning to an spline.]]>
   <pubDate>Wed, 03 Dec 2008 11:46:12 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1401&amp;PID=3816&amp;title=copy-command#3816</guid>
