  <title>CAD Forum discussion (EN) : Dynamic Block - dynamic parameter value-attribut</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Dynamic Block - dynamic parameter value-attribut]]></description>
  <pubDate>Sat, 05 Sep 2026 14:54:49 +0000</pubDate>
  <lastBuildDate>Fri, 19 Apr 2024 18:28:48 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=14076</WebWizForums:feedURL>
   <title><![CDATA[Dynamic Block - dynamic parameter value-attribut : My question: is there any way...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=14076&amp;PID=39097&amp;title=dynamic-block-dynamic-parameter-valueattribut#39097</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=948906">pltdvd</a><br /><strong>Subject:</strong> 14076<br /><strong>Posted:</strong> 19.Apr.2024 at 18:28<br /><br />My question: is there any way to change the value of a dynamic block based on the attribute given to the block.<div>I have 2 attribute for my object: one to ID it (all different values), the other to put it within a category (several block could have the same value).</div><div>I would like to edit automatically my object based on the 2nd attribute's value. It's fairly easy to give new attributes and values to a block since it has a specific ID. But to change the value of a dimension parameter automatically... I'm having a hard time to find the solution.<br>Is there a lsp. file out there, that could help that matter?</div><div><br></div><div><br></div>]]>
   <pubDate>Fri, 19 Apr 2024 18:28:48 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=14076&amp;PID=39097&amp;title=dynamic-block-dynamic-parameter-valueattribut#39097</guid>
